![]() Drives: 2017 Camaro SS 2SS Join Date: Jun 2017
Fuel Pressure
What fuel pressure is the low side pump trying to maintain? Ive been watching the fuel pressure with my aeroforce gauge and it seems to be between 45 and 55. I am going to get my nitrous bottles filled, but may have the wrong fuel jet in. I have it jetted for 55 PSI. Now I'm thinking it needs to be jetted for 45. Also, what's the minimum pressure I want to maintain to safely supply the high side? I tried to search this, but couldn't find any actual numbers.
Bump
![]() Drives: SRT4, 2ss Join Date: Nov 2016
Since you have an Aeroforce gauge you should be able to view the commanded fuel pressure.
Heh, i thought it could read what HP tuners could as far as logging parameters. Looks like I was wrong.
Here is a list of parameters the gauge can show. General Motors (CAN vehicles) – CN series gauges - Pg.2 http://aeroforcetech.com/files/parameters_features.pdf |
#6 | |
#7 |
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Mar 2016
So is 55 the pressure the low side is trying to maintain or is 55 the minimum to maintain safely to the high side? Also what source did the answer come from?
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
#8 |
#9 |
Class
Right now i am going through an automotive class and need in-depth specifications on the fuel system of my 2018 Camaro SS. I've been looking and will continue looking until i find something. Does anyone have a certain website that gives a break of the fuel system primarily.
#10 | |
