Old 04-22-2018, 12:22 PM   #1
GP86
GP86's Avatar
Drives: 2017 2SS
Tire is inside out. What to do?
I just put my stock wheels back on for summer with Michelin PS4S tires. As I was coating the wheels with ceramic, I realized one of my front tires was mounted inside-out by Costco. I'm only now realizing this after the tires have somewhere around 10-12K miles. What should I do about this? It seems like having the tire remounted in the correct orientation would not be advisable since it has so many miles on it already. Will it be fine to just leave it as is?
2017 HBM 2SS A8|F55|NPP|H01|IO6|RIK|WGL|56R
GP86 is offline   Reply With Quote
Old 04-22-2018, 12:41 PM   #2
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Go back and tell them you want a new tire.
Make a big deal about safety and that you will call head office.
Old 04-22-2018, 02:14 PM   #3
JeromeS13
Drives: 2017 1SS/1LE
I doubt that would get you anywhere. I would, however, take it back to them and insist they dismount and remount the tire properly.
Old 04-22-2018, 02:48 PM   #4
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
I'd second Jerome's suggestion and get them to remount the tire correctly. Should be good to go after that.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 04-22-2018, 07:11 PM   #5
CT ZL1
CT ZL1's Avatar
Drives: 2018 ZL1
Dont get your tires installed by costco because stuff like this happens. I have heard horror stories about rims getting damaged etc...
Past Rides
13 Porsche 911 4S
17 BMW M4
16 Shelby GT 350
07 Saleen Mustang
02 M3 Comp Pack
79 Corvette
CT ZL1 is offline   Reply With Quote
Old 04-23-2018, 01:25 PM   #6
Carlos_MRRWheelsInc
Carlos_MRRWheelsInc's Avatar
Drives: camaro
yes get them mounted properly. the last thing you need is to get involved in a accident do to traction/ oils/ water etc.
Carlos_MRRWheelsInc is offline   Reply With Quote
Old 04-26-2018, 05:40 PM   #7
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Costco
Old 04-26-2018, 07:15 PM   #8
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
I'd like to see a picture of this...there's no way that could look correct enough to run 10K miles before you realize it. Or at least that is what I think in my head as I have never seen an inside out tire live on a wheel on a car.
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 04-27-2018, 10:02 AM   #9
Rock-It Man
If you google this tire you will see that the tread pattern, while asymmetric, might be easily mis-mounted unless you look at the "outside" marking on the sidewall.
What's really asymmetric about these tires is the tread compound, so yes, the tire should be remounted ASAP.
Old 04-27-2018, 10:24 AM   #10
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
That's not "inside out" that's "backwards".
Emoto is offline   Reply With Quote
Old 04-27-2018, 11:38 AM   #11
Rock-It Man
Most tires are not directional, so they can be on either side of the car, rotating in one direction or the other.
What type of tire you have is AWAYS indicated on the sidewalls.
Asymmetric tires are marked "OUTSIDE".
Directional tires are marketed with an arrow and "ROTATION".
Some tires are both directional and asymmetric, and can't be swapped side to side. They have both markings.
Some tires are directional only, and can be on either side of the car, but only by remounting to preserve directional orientation.
Any real tire shop knows this, just not the kid mounting tires at Costco.
