Drives: ZL1 ATS-V CTS-V C7Z Range Sport SC Join Date: Mar 2016
Mike M. has been a client of ours for a few years now, starting out with his C7 Z06, then a Porsche Turbo S, and now he's also added a ZL1 1LE for track duy till his GT3RS comes in. He loves his Forgelines and we do too! He chose to do the GA1R open lugs with comp caps in transparent smoke in OEM sizes for the OEM tires. These wheels are super light and strong, weighing in under 20lbs per corner!
It turned out killer! Any of you want the a set of wheels, give me a shout. We are a master dealer for them all and our pricing is unparalleled ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
SABIO
Super Yummy...
Not that I would lick them... .maybe...
Sarcasm loading --------
price???
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
Been waiting to see a ZLE on these wheels.
Very nice ![]() |
#7 |
![]() Drives: 2018 ZL1 1LE Join Date: Aug 2017
When I called Forgeline a few months ago, they told me they didn't have the tooling to do the stock offset on the front for the ZL1 1LE. The front should be 19x11 with 11MM offset. Did something recently change with Forgeline or are you running a different size/offset?
#8 |
![]() Drives: 18 ZL1 1LE Join Date: Sep 2017
I got the same information when I called forgeline a few weeks ago - best offset they can do for front is 16 so you need to run a 5mm spacer in front to get oem offset
#9 |
![]() Drives: 17 Camaro ZL1 6MT Join Date: Sep 2017
Holy Crap those look phenomenal.
#10 | |
![]() ![]() ![]() ![]() Drives: ZL1 1LE Join Date: Oct 2016
#11 |
![]() Drives: '18 RH ZL1 1LE Join Date: Apr 2018
What are the exact specs for this ~$6k set of wheels?
#12 | |
![]() Drives: 13 Camaro SS Join Date: Oct 2012
![]() I would like to know if there is a spacer used here. Either way an awesome set of wheels and exactly what is needed for these cars since anyone buying them will definitely want a second set of wheels/tires. |
#13 |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
Zoom in - is it just me, or does it look like there is a shiny ~5mm spacer, in view, right under the valve stem in the shot?
#14 | |||
So, if you want to stick with the OEM tires, you can either run the slightly less aggressive wheel or run a 6mm spacer - which we sell as well. Or you can do an 18x11" with Hoosier R7s for the track and stick with the OEM offset. I realize they're a little different, but as you can see in the pics, the .25" is not hurting the look of that car haha
| Tags |
| aftermarket, custom, forged, forgeline, wheels |
