![]() Drives: 2016 M6 Hyper Blue 2SS Join Date: May 2016
Mods and a Tune
Okay so you can see the mods in my sig... anyone with similar mods do you really notice much of a difference compared to stock? I hardly notice the difference I figured it would be day and night difference especially after a tune but maybe I am expecting too much? I should of tested more pre tune to help compare. So after being tuned felt like I was fooling myself saying its faster because I wanted to believe it. I downloaded a g-force application on my phone (I know it can not calculate true G's but it can compare numbers still on the pull). So on pump it showed me the following. I feel like I may have expected more.. not power but more feeling on the butt dyno if you get where im coming from.
2nd gear 0.53 on E 0.55 3rd gear 0.36 on E 0.42 4Th gear 0. 27 on E 0.34
16 2SS M6 // Kooks 1- 7/8 w/Off Road Pipes // RotoFab w/Oiled filter // Custom Axle Back Exhaust // E-85 Sensor // Tuned SOLD!!
![]() Drives: Red Hot 2017 Camaro SS A8 Join Date: Oct 2017
I’ve notice a big difference in my car TSP 1 7/8 with no cats K&N Cold Air Dry Filter and Dyno Tune but it’s a 8 Speed Auto
My main thing is E85 compared to my normal pump tune it seems hardly any difference. Im wondering if they tuned me for pump and didn't tune me on E85? maybe they just activated the sensor. I would assume if so you can still run It with the tables already in the computer. I was also told I made 504HP and that really confused me because with the mods I have I expected 460-475 maybe? Also this is a HUB/Chassis dyno and is known to read lower than a Dyno Jet and a Mustang Dyno, its called Mainline popular dyno in Australia. I have noting against the shop they were all nice and respectful seem to work on a lot of LS engine cars. Awesome guys, just confused I guess and sorta needed to vent. I kinda was thinking if you have 504 HP would you lose traction going WOT in 2nd gear maybe in mid RPM range or at least chirp the tires?
#4 | |
Ill say this E85 outside of a cam is the single biggest power adder NA, so either your sensor is not working or the tune is not. You should be able to check you HPTuner software and there is a read out for E85 content.
#5 | |
Maybe if I get an HP I can get someone with experience to look at it and read my logs.
![]() Drives: 2016 2ss Camaro Join Date: Oct 2013
Something isn't right. You should notice the night/day difference you are referring to. I also started with similar mod's as yours and thought the car wasn't performing as well as others I'd been reading about. Come to find out it was the tune. I'm not about to talk bad about anyone that's not who I am. I had Brett at Pray Performance re-tune my car and It picked up what I was missing. Mine is a A8 so part of my tune was the transmission. That was my experience.
427 Pray Head/Cam/Converter, Pray Ported Highram, 103mm TB, Pray Tuned, 3030 Drag Pack, Roark OTR CAI, TSP Headers, E85, UDP Best times 1/4 n/a 9.23@146.96, 1/8 5.91@118 |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Audi TT RS Join Date: Jan 2014
Your first indication of it being the tune is the difference, or lack thereof, between pump and E85. I would get a tune elsewhere.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
#8 |
Yeah I think i will have to do that. I don't need the stock tune in order for another tuner to make any needed adjustments right? They used an HP on it.
#9 |
E85 is not going to make any difference in power alone. The power comes from being able to increase timing. In Hp tuners, go to Spark, Flex fuel Spark and see if the table has been adjusted correctly. Should be upwards of 4 degrees of advance in that table. The increased timing is what nets the power gain. You should be seeing 27-28 degrees total at wot on E. There are other tables that need addressed as well.
#10 | |
BAMF SS
And I think the 27-28* of timing is about the max for 93 octane. |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Join Date: Jul 2016
From my experience your not going to get any more than 24* in the car on pump without seeing some sort of KR. The prime point for E seems to be 26-28* depending on the car. The oxygen in the E will give some gains but the couple of degrees of timing does the rest of the work.
#12 | |
BAMF SS
#13 |
![]() ![]() ![]() Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
What was the e content in your tank when the car was tuned? Perhaps the tune needs an adjustment if you weren't > 60% e.
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ |
#14 | |
With flex sensor, E content is reported to the ECM, ECM then adjusts Stoich, PE, and timing values based on E percentage it sees. So if he was seeing 78%, then he should be netting 95% of the gains unless his Stoich, PE, or Flex fuel spark tables are not setup correct. Even if Ethanol content was below 60%, the ECM should correct it automatically being it has tables from 0-100%. So you don't have to tune for a specific percentage...that is the whole point of a flex fuel sensor.
2016 NFG SS A8/Whipple 2.9/Fuel System/Flex Fuel Last edited by KingLT1; 04-23-2018 at 09:05 AM. |
