Old 04-19-2018, 05:43 PM   #1
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Differences to ZL1 brakes
What are the differences of our SS-1LE's brakes to the ZL1 (non-1LE) brakes?
Old 04-19-2018, 06:41 PM   #2
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Just a small note, the ZL1 & ZL1 1LE both feature identical braking systems except for the paint on the calipers.
SS 1LE front rotor diameter: 14.6"
SS 1LE rear rotor diameter: 13.3"
ZL1 front rotor diameter: 15.35"
ZL1 rear rotor diameter: 14.4"
Both use a 6-piston caliper, the ZL1s is slightly larger in size. I believe the pad compounds are identical, though the sizes are different.
There's a useful thread in the sticky area of this sub-forum with info on brake pads for the SS 1LE. http://www.camaro6.com/forums/showthread.php?t=475866
Old 04-19-2018, 06:55 PM   #3
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
You mean 14.6" for the SS 1LE front rotor. Everything else is correct. The ZL1 rotors are also slightly thicker, and the front ZL1 rotors are "kangaroo paw" instead of the SS 1LE's directional vane for their internal cooling structure.
Old 04-19-2018, 07:00 PM   #4
Mr. Wyndham
My mistake!! I confused the SS rotors with the SS 1LE by accident! I've edited the post.
never heard "kangaroo paw" before! That's pretty good!
Old 04-19-2018, 08:33 PM   #5
Eldi Z
So if calipers are similar, would it be possible to only change over the rotors of the ZL1 and mount them in the SS-1LE?
Old 04-19-2018, 08:47 PM   #6
Subcool
Drives: 2022 SS 1LE
So are the 1 le calipers the same as the 6 piston brake upgrade for the standard ss?
Subcool is offline   Reply With Quote
Old 04-19-2018, 09:08 PM   #7
TJay74
Yes, the only difference is the 1LE gets the solid surface rotor where the kit has the slot cut rotors.
Old 04-19-2018, 09:39 PM   #8
EXSSIVE
EXSSIVE's Avatar
Drives: 2016 Camaro 1SS M6
I wonder if the master cylinder bore diameter gets changed with the ZL1... Might be something worth looking into.
EXSSIVE is offline   Reply With Quote
Old 04-19-2018, 10:15 PM   #9
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
1LE and ZL1 master cylinders have the same part number.
'18 1SS 1LE Black, PDR
Old 04-19-2018, 11:20 PM   #10
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
How are you going to fit the calipers over the bigger rotors? The calipers are solidly attached to their mounts.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 04-20-2018, 09:54 AM   #11
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
We need a ZL1 brake upgrade package! The 1LE brakes are great on tack so far, but wonder what it be like with the ZL1 brakes front and rear. I noticed the Zl1 rears have 2 different part numbers depending if you want the A1Z PKG
Old 04-20-2018, 10:25 AM   #12
Dave-ROR
Drives: A few
Can you lock up the tires/engage ABS with the current brakes? If so, you won't have any difference in stopping. You will have more thermal capacity, and more unsprung rotational mass. One of those is good (if needed), one is bad.
Unless you need more thermal mass there is quite literally zero reason to swap out to ZL1 brakes - unless consumables are cheaper in which case you might be able to make a long term financial benefit out of the swap. Other benefits could be better modulation but with the 1LE 6 pots I doubt there's much of a problem there to begin with.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback
Too many cars.. never.
Dave-ROR is offline   Reply With Quote
Old 04-20-2018, 10:36 AM   #13
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
The pad surface area is greater with the J6H (ZL1) brakes over the J6M (SS 1LE) especially up front. The J6H calipers are machined to accept the larger rotors plus they are larger overall, like the pads, up front is most noticeable. They have larger pistons as well both.
RUQWIKR is offline   Reply With Quote
Old 04-20-2018, 04:21 PM   #14
carguy55
carguy55's Avatar
2 things I always want more of in a car, horsepower and brakes
