Old 04-18-2018, 07:42 PM   #1
Cupahaters
Drives: 2017 fifty camaro
UPGRADE THE BOTTOM END OF MOTOR.
Advise on what piston, crankshaft, etc for the bottom end of the motor. Want to start there and then probably go Hellion twin turbos. Just want to be able to get as much horsepower out of the motor I can.
Thanks for any suggestions and help.
Cupahaters is offline   Reply With Quote
Old 04-18-2018, 09:05 PM   #2
Drsagacity
Drsagacity's Avatar
You may want to check the forced induction section, we have had quite the thread on drop in pistons, rods, rings...the right choice may come down to your plans...will you be pulling the motor anyway?
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 04-18-2018, 09:52 PM   #3
Cupahaters
Whatever I need to do. I just know that if I ever have plans over 700 I need to change it. So figured I will do it first.
