![]() Drives: 2018 ZL1 1LE Join Date: Jan 2018
Transporting your ZL1 to the track
How do you do it?
Driving to the track? Trailer? What truck do you use? |
![]() Drives: 2018 camaro zl1 , 2007 porsche GT3, Join Date: Dec 2016
Trailer with a ford raptor
![]() Drives: 2017 Camaro 1LE Join Date: Oct 2016
Enclosed trailer
![]() ![]() ![]() ![]() Drives: 1970 chevelle Join Date: Aug 2011
When I finally get the zl1 1le I will trailer enclosed with an atc aluminum trailer pulled by a 2017 gmc 2500 all terrain diesel which is how it’s coming home since the roads aren’t great in nh yet and I will take it directly to the ppf installer.
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car 2015 Z06 Z07 Daytona Sunrise Orange Metallic Dads Car 2013 ZL1 vin 963 Crystal Red Tint Coat/Black Wheels Exposed Carbon Fiber Insert 6 Spd Manual |
Enclosed trailer is a really good idea.
I am looking at my options. My girlfriend has a Toyota Highlander but it’s not strong enough. |
Jspeed is that a 24ft enclosed? I'm looking at one of those now as I stay all weekend a lot of times at the track and feel my car is much safer. What brand do you go with? Are you using a winch since its so tight inside the trailer as it looks like you'd have to crawl out the window if you drive it in. I've been using an open trailer for years but I think its time for a change to an enclosed. I've been looking at the Stealth 24' Titan, no Rivets which is good since they have a tendency to start looking bad after a few years.
#7 |
![]() Drives: 2018 ZL1 Join Date: Jul 2017
Drive it to and from! my trailer is AAA so far have not needed it
#8 |
![]() ![]() ![]() ![]() Drives: ZL1 1LE Join Date: Oct 2016
I have been driving it, but I may start using an aluminum open trailer depending on the track and what I want to bring.
#9 |
![]() Drives: 2013 SS 1LE Join Date: May 2017
Just drive it to and from the track. I drove the 2SS 1LE back from the track with metal on metal front brakes. its fine
#10 |
![]() Drives: E92 M3 & E36 M3 (Full Race car) Join Date: Jul 2017
#11 |
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Because racecar, 18ft steel deck with Etrack. 2017 5.7L 8speed RAM pulls down the road with the cruise set at 82mph just fine in 7th gear.
#12 |
I used to be Dragoneye...
Same setup here, except wood deck and a Silverado 1500 5.3L...Also putting a winch on it.
#13 |
![]() ![]() ![]() ![]() ![]() Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
#14 |
![]() Drives: 2010 SW SS/RS 2018 ABM ZL1 Join Date: Sep 2009
with the straps crossed they are pulling into each other and it will keep it from moving. its possible for it to move left or right when pulling straight if the car bounces at all. Not saying it will but it can. Standard practice it to cross tie everything if possible.
