Old 04-17-2018, 11:21 AM   #1
mdbennes
mdbennes's Avatar
Drives: '18 Silver SS 1LE
Garage pics?
Slowly getting my garage accessorized but wanted to see what all you pros have and some ideas as well. Post pics if you don't mind....
Retired Air Force (2014)
2018 Silver SS 1LE
Past Rides
2000 Corvette FRC
2000 Corvette Coupe
2002 Corvette ZO6
2005 Corvette Coupe
2016 Corvette Stingray
mdbennes is offline   Reply With Quote
Old 04-17-2018, 01:30 PM   #2
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2020 2SS
https://vault.myvzw.com/webcs/app/sh...ite/RTXIQJVxeL
https://vault.myvzw.com/webcs/app/sh...ite/vPu43ScMy5
Why can't I get the images to show up??
Bad Anvil Garage is offline   Reply With Quote
Old 04-17-2018, 02:03 PM   #3
MackSteelPrivateEye
Originally Posted by Bad Anvil Garage View Post
Nice Gas Pump. Is it real or a replica?
Old 04-17-2018, 02:23 PM   #4
Blubyu2
Drives: 2016 2SS Hyper Blue
Camaro's New Home
After remodeling my whole house I finally got to the garage last year.
Blubyu2 is offline   Reply With Quote
Old 04-17-2018, 02:35 PM   #5
00 Trans Ram
00 Trans Ram's Avatar
Drives: 2017 2SS
Tips:
- Get a retractable air hose reel for your air compressor. Put the compressor out of the way (under your workbench?) but where you can still turn it on. Run some standard air hose to the wall, up the wall, then along the ceiling to the middle of the garage ceiling. Attach the hose reel to the ceiling, with the end of the hose (hose on the reel) dangling down far enough to reach it, but high enough to not be in the way of cars or your head. Then, you can have a hose that reaches anywhere in your garage, but also have it out of the way when you need it.
- If you are remodeling, get as many outlets as possible. And, have them at chest height. If not, get some 6' long power strips (https://www.globalindustrial.com/p/e...0aAs6yEALw_wcB) and mount them on the wall, or the front of your shelving. This way you can plug things in easily.
- If you have a work bench, mount a standard (or 2!) power strip right above it (eye level, actually - so the cords aren't intruding on your bench) so you can power tools without reaching far.
- For a cheap workbench, make it out of 2x4s for legs, with some cross bracing along the sides and back (not front). Make the top out of 2 layers of 3/4" plywood. Then, cover the top with medium thickness galvanized steel. Cheaper, lighter, and easier than a metal bench, but almost as sturdy and durable.
- Mount vices, grinders, etc. on the corners of the bench.
- A peg board behind your bench works nicely. Either to hang tools, or spare parts and other misc crap.
- If you have a tool chest, label the drawers. And, place it right next to your workbench so you're not walking far to get stuff.
- Get good lighting. More = better. I went to Home Depot and bought the cheapest 3-bulb fixture I could find. Any wattage works, since you'll be using LED bulbs and can stick a 100w-equivalent into a fixture rated for only 15w bulbs. Then, screw 3-4 of these fixtures to a single 2x4. Hang the 2x4 above your workbench (literally - hang it by a chain on hooks in your ceiling) and splice all the wires into an extension cord. Plug the cord into your power strip. Then, when you turn on the strip, your lights come on. I have 12 100w (equivalent) LED bulbs above my work bench. And, if I need, I can remove it from the ceiling and put it under a car, or wherever. Compare my 19,200 lumens of light against a standard shop fixture of 3500 or so.
- If you are hanging new ceiling lights (assuming 2-car garage), put 4 of them in. 2 in the center, running end-to-end parallel to the cars, and one on either side of the car. That way, the light comes down on the sides of the cars (and reflects underneath a bit) rather than on top of the cars (creating a shadow underneath).
- Paint walls white, so that the whole garage is brighter.
Can't think of any other things off the bat. Will update if I do.
00 Trans Ram is offline   Reply With Quote
Old 04-17-2018, 02:40 PM   #6
BowTieWise
BowTieWise's Avatar
Drives: 2017 Camaro 2SS A8
this thread should be good
2017 2SS. A8. Summit White
SOLD: 2014 1SS/RS. A6. Red Hot. Z/28 Spoiler. ZL1 Strut Tower Brace. Cold Air Inductions CAI. Borla ATAK Catback. Custom Graphics from Wise Graphics & Design.
BowTieWise is offline   Reply With Quote
Old 04-17-2018, 03:04 PM   #7
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
I have a big garage (it is a 3-wide but the last bay is double-deep so it can fit 4 cars on the ground and enough room for 2 lifts) but it is new construction and I gotta finish the rest of the house before I do my "Dream Garage" build. One day I will be cool like you others.
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 04-17-2018, 03:05 PM   #8
chrest
chrest's Avatar
My 3 car garage that is coming right along. Lots of time is spent out here.
2017 NGM 2SS NPP M6 MRC
Vortech SC, 2" TSP LT No Cats, Borla X, Eibach,
Hurst shifter
603hp/547tq
chrest is offline   Reply With Quote
Old 04-17-2018, 03:07 PM   #9
chrest
chrest's Avatar
what kind of flooring is this?
Hurst shifter
603hp/547tq
Old 04-17-2018, 03:08 PM   #10
samurai
samurai's Avatar
Drives: C8 Corvette
I'm just glad my Camaro fits in
samurai is offline   Reply With Quote
Old 04-17-2018, 04:12 PM   #11
mdbennes
mdbennes's Avatar
Those are some great pics! I have a 3 car garage, making the single car garage my woodshop, with the 2 car my GARAGE CAVE of sorts. I've added some flags, my Air Force flag, SOCOM flag, US Flag and FSU flag on some of the walls/ceiling.
2018 Silver SS 1LE
Past Rides
2000 Corvette FRC
2000 Corvette Coupe
2002 Corvette ZO6
2005 Corvette Coupe
Old 04-17-2018, 04:47 PM   #12
Bad Anvil Garage
Look closer. It's actually a mini beer fridge sitting on a black drawer unit. I made parts, bought parts, made decals, added lighting, etc. to make it look like a gas pump.
https://vault.myvzw.com/webcs/app/sh...ite/gBcG1RbmQi
https://vault.myvzw.com/webcs/app/sh...ite/FFNR3ehSs2
Old 04-17-2018, 05:13 PM   #13
2K16SummitSS
Resident Land Surveyor
2K16SummitSS's Avatar
Drives: 2016 Camaro 1SS - Summit White M6
That just made it even more awesome. Great work on that piece!
2016 Summit 1SS 49th Anniversary Commemorative Limited Plutonium Edition - M6, Solo Axleback & !RearCats, Ultra-Rare Cloth Seats, Forgestar CF5V 19x10-285/35 19x11-325/30
2001 NBM Trans Am WS6, Wifey's Grocery Getter - Torquer V2 cam, Racetronix Fuel Pump, Yank 3000 Stall, Transgo 1-2 kit, TSP LTs, Magnaflow, Strano Springs/Koni STR.T shocks, 17x9.5/17x11 TTIIs, Ed Wright tuned
2K16SummitSS is offline   Reply With Quote
Old 04-17-2018, 06:16 PM   #14
GroundhogSS
GroundhogSS's Avatar
Outstanding work there.
Richard
Delivered: 08/15/2016
#TeamBeckyD
