Old 04-17-2018, 10:30 AM   #1
mbar
Drives: 2016 1SS
Raybestos ST45 short review
Mods: this review is at the 1LE subsection since it's regarding 6 pistons Brembo.
After using Raybestos ST43 with my 4 pistons kit, I realized that the braking system is just too small for a more advanced track usage, hence my upgrade to the 6 pistons system. Ran Summit Point Front ST45 rear ST43 (leftover pad) + with Stock 1LE rims/tires. Weather 40-50F .
On track:
Pros: Very firm initial bite (much higher compared to ST43). Linear torque curve . Superb pad wear - 2 days (weekend) at Summit Point only used 0.5-1 mm of pad. With the 4 pistons (yes it's clementines to oranges) I've used half to a full pad in one weekend on that track. Rotor thickness still measure 34mm , but too hard to call this one yet. I let an instructor drive around with the car and he said that the pad feels similar to his Ferodo DS1.11
Cons: These pads are not completely on/off but getting closer to it. Pedal release is not as easy compared to ST43, which require more precision and skill for trail braking.
Street:
Pads worked from cold at 25F without any issues. Very minimal squeal if using brake lube on the backing plate.
I don't think it's ideal to daily drive with these pads, because they will grind your rotors down.
Questions? let me know
Thanks
1SS, Black, Black Wheels, A8, MRC, NPP
mbar is offline   Reply With Quote
Old 04-20-2018, 08:54 PM   #2
mbar
Drives: 2016 1SS
Update: I had no issues swapping back to the stock Ferodo pads. Didn’t even clean the rotors before.
Old 04-25-2018, 01:33 PM   #3
citizennick
Drives: 2016 2SS
What are the part #'s for these (6 piston)? I'm looking to run a new pad at the track. Was originally looking into the ST43.
2016 2SS M6 Black/Adrenaline Red
589rwhp 572rwtq 429 LT1
citizennick is offline   Reply With Quote
Old 04-25-2018, 02:57 PM   #4
mbar
Drives: 2016 1SS
Front size is 1405
