Old 04-17-2018, 05:40 AM   #1
CAMAROJET
Drives: Camaro 2016 SS2 Hyper blue
Daytime running lamps
Hello
my left DRL has stopped working. Before I order a new one, and spend 210 US$. i was wondering:
How do I know if the problem is not from the lapm, but rather from the controle module?
Anyone has a guess?
2016 Camaro Convertible
Matt Olive green
CAMAROJET is offline   Reply With Quote
Old 04-17-2018, 05:48 AM   #2
ecko04
Drives: Too many to list
Warranty?
It’s a LED module, not a bulb. They aren’t supposed to just fail (at least not so soon). If you had it fail this soon, it’s probably premature failure and would be covered under your bumper to bumper warranty if you took it in.
Sent from my iPhone using Tapatalk Pro
ecko04 is offline   Reply With Quote
Old 04-17-2018, 10:20 AM   #3
Nsxmatt
Drives: 2017 Camaro
I'm assuming your car has a full wrap, since the lights were removed during that I'd check to see if it's simply unplugged or something else since these LED's don't have a habit of just failing after 2 years.
Nsxmatt is offline   Reply With Quote
Old 04-18-2018, 04:12 AM   #4
CAMAROJET
I got it painted. but same procedure so they removed many parts and installed it again. no wi have this light that doesnt light up. I tried to follow the cables but i cant get an accurate diagnosis. If i use a scanner, it will show an error not what is wrong exactly. and to remove it, i have to bring out the bumper again...
I got the microphone not working too. but this one is just a defect. I need to replace but i cant abstein from using my car.
and the radio is not picking up stations. cables are in though. trying to find out if the antenna amplifiers need a power supply cable. it has two cables plugged in which should be enough. cant find its wiring diagram to be sure.
Matt Olive green
Old 04-19-2018, 12:39 PM   #5
drfeelgood
drfeelgood's Avatar
Drives: 2017 ZL1 Convertible A10
you need to find new people to work on your car. somebody jacked your stuff up. I have had my car damn near dissembled for my audio install and everything works perfectly. I would just take it in, too many things to try and diagnose
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq)
'17 Maserati Levante- STOCK
drfeelgood is offline   Reply With Quote
