Old 04-16-2018, 04:12 PM   #1
Epx998
|Engineer|
Epx998's Avatar
Drives: 2016 Camaro SS
LT4 fuel upgrades install time?
I am getting the LT4 HPFP, injectors and ZL1 fuel pump assy. installed along side my Magnsuon blower - anyone know what the general install time for the fuel upgrades portion would be?
Epx998 is offline   Reply With Quote
Old 04-16-2018, 05:58 PM   #2
oldman
Drives: SS 6 speed of course
With the intake off, the HPF system: including injectors, would take say 40 minutes to R and R at a normal place, I 'm sure some will claim 20 minutes, but we are not talking about racing, heck somebody with all the tools lined up and parts our to the bag probably put that under 10 minutes... till a clip breaks off one of the injectors... The LP side... well gotta drop the tank and to do that.... will it gets interesting.
Old 04-17-2018, 09:13 AM   #3
parbreak
Drives: 2017 50th Camaro SS
I'll be doing the full system soon but I plan on an auxiliary low side pump rather than dropping the tank. More money, less headache.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 04-17-2018, 10:05 AM   #4
oldman
My thoughts too, plus they seem to supply more vs the LT4 LPs intank.
Old 04-18-2018, 09:53 PM   #5
Razor427
Drives: 2016 Camaro 1SS
Who has best pricing on LT4 injectors and Pump?
Ray
Razor427 is offline   Reply With Quote
Old 04-18-2018, 10:12 PM   #6
Epx998
|Engineer|
Epx998's Avatar
Added time to deal with one of the fuel lines. The one shipped with my flex fuel sensor is not long enough, the one shipped with my Mangsuon is mostly long enough, but crimps near the left side adapter. My shop is going to fabricate me a new one since the ones I was given don't quite fit.
It doesn't look so bad in the photo, but when held exactly how it needed to be..
Old 04-19-2018, 08:49 PM   #7
TJay74
So where is the HPFP located at, under the intake?
I am tempted to put the LT4 injectors and HPFP in my 1LE before I drop it off for the Procharger install.
Old 04-19-2018, 09:46 PM   #8
Drsagacity
Drsagacity's Avatar
Sorry, I am dumb on this one. What are the options for a "low side pump" instead of the in-tank pump. I didn't realize there was another option.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 04-20-2018, 10:22 AM   #9
SSnakeEater
DSX makes an auxiliary pump that to my knowledge pushes more fuel than the LT4 in tank pump. The only caveat is you have to drill into the gas tank. Kind of scary at first but the whole system takes less than 2 hours to install. Whereas the in tank is like 6-8 hours I believe.
SSnakeEater is offline   Reply With Quote
Old 04-20-2018, 03:02 PM   #10
parbreak
I'm looking at the DSX kit which is $1000 and the Skid Mark Garage kit which is $600. Skid Mark says they use the same Walbro pump that DSX uses. I have the DSX E85 kit so I would like to use their kit but $400 difference is significant.
Old 04-20-2018, 03:29 PM   #11
SC88
Twin Turbo
SC88's Avatar
Drives: 2016 2SS
Removing the Exhaust and Driveshaft is probably the most difficult part of dropping the tank.
If your going to drop it make sure you have the fuel level below 1/4 tank & have the lock ring tool to properly install the lock ring.
Boost, Boost & More Boost
Instagram = BoostedSS
SC88 is offline   Reply With Quote
Old 04-20-2018, 04:54 PM   #12
jeffm4688
Drives: 2015 Camaro 2SS 1LE
Gm book is 3 hours labor on in tank pump. Ironic that I pulled my motor and did everything but the LT4 LP side pump, but it did take the shop right around 3 hours to install it.
2015 2SS - Base A6 - Sold/Brother/Traded
2016 Camaro 2SS - A8 | MRC | NPP | 725rwhp - RIP
2015 2SS 1LE - RS/Sunroof Mods: Headers, Borla ATAK, intake - Sold
2018 M2 Exec - Current
jeffm4688 is offline   Reply With Quote
