Old 04-16-2018, 03:14 PM   #1
Navigator
Navigator's Avatar
Drives: 2020 Camaro 2SS
Heat blowing out when climate control is off?
Lately I've been noticing that heat continues to blow out even when the climate control "power" button in the center is set to off. I usually leave the temperature dial set at 70 degrees and leave the buttons for where I want the heat coming out remain lit, so I have everything set how I want it when I press the "power" button back on. Am I missing something? Shouldn't that climate control power button override every other button that remains lit, or do I have to turn every button off?
Navigator is offline   Reply With Quote
Old 04-16-2018, 03:16 PM   #2
grampa_ss
grampa_ss's Avatar
Try pushing the re-circulation button. That's what works for me.
Old 04-16-2018, 04:08 PM   #3
Navigator
Navigator's Avatar
Will do, but still seems odd that any heat should come out when the power button is off. The car almost seems hotter with the power set to "off" than when I have it on.
Old 04-16-2018, 04:25 PM   #4
trueraiderfan17
Drives: 2018 ZL1 A-10
I have noticed this as well. Let me know how pushing the re circulate button helps.
trueraiderfan17 is offline   Reply With Quote
Old 04-16-2018, 08:33 PM   #5
Nsxmatt
Drives: 2017 Camaro
If you are moving and the recirculation button isn’t pressed then outside air is blowing over the heater core into the car depending on the last setting of the blend door actuator. This is completely normal and every car does this.
Nsxmatt is offline   Reply With Quote
Old 04-16-2018, 08:33 PM   #6
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Power the fan off completely and lower the heat temp to low.
lt4camaro is offline   Reply With Quote
Old 04-16-2018, 10:46 PM   #7
metros11
Drives: 2018 SS 1LE
This.
metros11 is offline   Reply With Quote
Old 04-16-2018, 10:51 PM   #8
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
Yep. Noticed the same thing and doing this takes care of it.
torqueaddict is offline   Reply With Quote
Old 04-17-2018, 11:33 AM   #9
Navigator
Navigator's Avatar
So what is the point of the on/off button then?
Old 04-17-2018, 11:48 AM   #10
lt4camaro
lt4camaro's Avatar
You have the controls to shut down incoming air flow and a control to allow only ambient air temp, not heated or cooled . The system works just fine, not sure what you want the heating, ventilation, and cooling system to do ?
Old 04-17-2018, 01:11 PM   #11
Navigator
Navigator's Avatar
to not blow out heat when it is set to off?
Old 04-17-2018, 01:17 PM   #12
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2020 2SS
What about the rear defogger turning itself on automatically at times upon startup? Anyone ever have that issue?
Bad Anvil Garage is offline   Reply With Quote
Old 04-17-2018, 01:29 PM   #13
Kise
Kise's Avatar
Drives: 16' 2SS, 06' Silverado SS
should be able to change that in your settings.
Kise is offline   Reply With Quote
Old 04-17-2018, 01:51 PM   #14
lt4camaro
lt4camaro's Avatar
By making sure the blower fan is completely off and turning temp down to low setting , you shouldn't get anything thru the vents other than outside air temp. I agree that if you park a car with 195 degree water temp and out in the sun it will heat soak and upon start up you will feel heated air coming thru the vents until it exhausts that heated air. Make sure your recirc setting is set to recirculate outside air not inside the car air.
