Old 04-15-2018, 10:15 PM   #1
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
Hit the strip last weekend
Stock 2017 A10
Only managed two runs as a Mustang oiled down the track right after my second run.
First run right off the highway. Went through Tech, then drove straight to the staging lane.
11.58@128.02 with a 2.07 60ft. All nannies on.
Waited ~20 minutes then made a second run.
11.61@126 with a 1.97 60ft. All nannies on.
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 04-15-2018, 11:19 PM   #2
Chevyman2
Chevyman2's Avatar
Drives: 2018 zl1
What mode?
Chevyman2 is offline   Reply With Quote
Old 04-16-2018, 07:49 AM   #3
Blown355
Blown355's Avatar
Track/Sport1
2017 ZL1
A10
Redhot with stripe
Old 04-16-2018, 08:25 AM   #4
IneedAZ
IneedAZ's Avatar
Originally Posted by Blown355 View Post
Track/Sport1
did u customize those settings or just raw Track and Sport 1?
I would think if u customize it u would do better. I would try Track for exhaust, Sport for trans, and Tour for Suspension to help give weight transfer.
Old 04-16-2018, 09:14 AM   #5
Fraxum
Fraxum's Avatar
OP, wow, you are doing about as good as me so far with nannies on and me with them all off. Your slip is hard to read. Wow, 128 MPH on that first run! Awesome. With a low 1.7 60' you will be flirting with 10 seconds.
Mine is stuck at 125, except for one 126 @ -1,300 DA. I guess mine is a slow one. Fooling around with the bypass adjustment is getting me nowhere.
And as we know Mustangs create problems in so many ways.
Old 04-16-2018, 10:34 AM   #6
Blown355
Blown355's Avatar
No customizing. I'm sure customizing it for the track conditions would reap benifits. I'll definately try that next time.
I also tried to launch the car myself instead of using Launch Control. I'm sure it could have launched better than I did.
2017 ZL1
A10
Redhot with stripe
Old 04-16-2018, 10:44 AM   #7
Blown355
Blown355's Avatar
I was definitely stoked when I saw 128 mph. My second run started off better than the first, but by the 1/8, the advantage was gone. Probably got a bit of knock retard. Still, 126.48 is still 5th best trap on the official group #7 list.
I guess ink is too expensive to put in their printer, cause I had this same issue with the timeslips last June.
2017 ZL1
A10
Redhot with stripe
Old 04-16-2018, 04:53 PM   #8
Boo
Drives: 2017 ZL1 A10 Nightfall Grey
Did you adjust tire preassure?
Boo is offline   Reply With Quote
Old 04-16-2018, 05:26 PM   #9
Blown355
Blown355's Avatar
Brought the rears down to 26psi. Fronts were at 36psi.
2017 ZL1
A10
Redhot with stripe
Old 04-16-2018, 08:03 PM   #10
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
Very nice mph!! Get that 60 down and you'll be in business!!!
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 04-17-2018, 07:44 AM   #11
Blown355
Blown355's Avatar
Going to focus on my launches next outing.
Looks like I'll be stuck between 17WhiteZL1 and Stephen12ZL1 on the fast list.
2017 ZL1
A10
Redhot with stripe
