Old 04-11-2018, 03:55 PM   #1
ExCrystal
Drives: 2017 2SS NGM
Uh oh, she started “shaking” - A8?
Long story short: car was at the dealer for 20 days due to an airbag sensor failure. Picked it up today, and my car was shaking/shuddering while at a stop. Not sure if it does it while moving.
Asked my service manager if it’s normal (I’ve read and asked about the A8 shudder problem on here), and he said drive it for a bit as it’s been sitting.
Should I worry? I’m going to drive it for a few days or so and see if it goes away since the car was not driven for 20 days. Car wasn’t shuddering or shaking before dropping it off. Thoughts?
Thanks!
ExCrystal is offline   Reply With Quote
Old 04-11-2018, 04:36 PM   #2
RunRS9114
RunRS9114's Avatar
Drives: 2017 Hyper Blue 2SS, A8, NPP
Hey ExCrystal. I had my SS in the shop for a couple of weeks getting some damage repaired from a kid backing in to my car. I had this same issue on the drive home from the body shop. I took it out for a 15-20 minutes drive afterwards and the issue went away and hasn't come back (this was about 2 months ago now). I think the LT engine just doesn't like to sit for extended periods of time or maybe they disconnected the battery for a while and it has something to do with that. Someone more technically inclined may be able to chime in!
RunRS9114 is offline   Reply With Quote
Old 04-11-2018, 10:17 PM   #3
ExCrystal
That's what I figured, too. No issue during or after my evening commute, though I did feel and head a weird vibration under slight acceleration while going up a slight grade on the road. When I'm pressing the gas lightly to go about 10-15 mph, I also hear a slight purr--not the purr of the v8! lol
I don't know - maybe it's paranoia, but I'm gonna give it a few days before I think about this further.
Old 04-11-2018, 10:23 PM   #4
Cameron27
Drives: 2015 2SS
Cameron27 is offline   Reply With Quote
Old 04-11-2018, 11:54 PM   #5
I also get this occcasionally (and never did with the previous V6 Gen6). Right now my lay guess is it's panel vibration caused by the V8's resonance happening to be the same as the eigenfrequency of a body panel at a certain rpm. Perhaps the reason we can only feel it going very slowly up an incline is that otherwise it gets suppressed by tire/road noise.
(As a side note, this is still nowhere near as bad as the clunky 3->1 downshifts I had with the A8 in the V6 under similar circumstances, which is not happening at all with the A8+V8 combo, this 8L90 specimen looks better so far.)
Old 04-12-2018, 12:45 AM   #6
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
The battery was disconnected for an extended period of time clearing the PCM VRam, so the PCM has to relearn its parameters outside base programming.
k
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 04-12-2018, 04:37 PM   #7
init4fun
Drives: 2017 50th Anniversary
Thanks!
Mine did this when I first took it out of storage. Actually thought the gas had gone bad but it had only been sitting for 4 months with a full tank and a full can of Seafoam in the tank. It cleared up in a couple of days. Actually it cleared up the first time I got on it hard but that took a couple ofdays as it was still cold in my area.
If they disconnected the battery for any length of time that could cause it as well .
init4fun is offline   Reply With Quote
Old 04-13-2018, 04:06 PM   #8
ExCrystal
Thanks for the replies and insight.
She's doing well for the most part. I still feel the car rumble a bit while driving only. Seems to be around 25-28 mph, going down a slight incline with a little pressure on the gas peddle.
