Old 04-11-2018, 10:59 AM   #1
trohde78
trohde78's Avatar
Drives: '17 Red Hot 2SS 6MT
No Cruise Control Cancel Button?
OK, this probably doesn't bother anyone else, but I can't believe that the engineers couldn't find a way to keep the cruise control cancel button when the car is also equipped with a heated steering wheel. I mean, they even split the button in half to add a separate piece with a light to say the heater is on.
Anyway, does anyone know if there is a way to code it so that cruise is always "on", and the on/off button would work as a cancel button?
trohde78 is offline   Reply With Quote
Old 04-11-2018, 11:13 AM   #2
Kise
Kise's Avatar
Drives: 16' 2SS, 06' Silverado SS
not sure if I understand your question fully but if you press the brake it acts as a cancel button but stays on.
if you want to fully remove it as in remove the symbol from your display you would press the center (cruise control symbol) button on the left (select button is on the right of the steering wheel, cruise control is on the left). if you hit that button it will turn off cruise control.
hope this helped.
Kise is offline   Reply With Quote
Old 04-11-2018, 11:42 AM   #3
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
I'll have to try it, but it sounds like the center button can function as a cancel.
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 04-11-2018, 11:48 AM   #4
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
This is what we have. I use it all the time.
Old 04-11-2018, 12:06 PM   #5
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
This makes me happy to not have a heated steering wheel as I have a cruise cancel button. I use that feature all the time but I don't need a heated wheel living in SC.
OP - good luck - I hope you find a way to make the cruise work a little better for you.
476 rwhp/440 rwtq (sold)
Old 04-11-2018, 12:15 PM   #6
Wolvie70
Wolvie70's Avatar
Drives: 2016 2SS, Summit White, A8, NPP
Wrong, it turns it off and you lose your set speed, you cannot press resume and go to the last set speed. The only way to cancel and retain the set speed is to use the brake. The whole thing is miss by GM.
Wolvie70 is offline   Reply With Quote
Old 04-11-2018, 12:16 PM   #7
Wolvie70
Wolvie70's Avatar
Nothing you posted indicates that.
Old 04-11-2018, 12:40 PM   #8
trohde78
trohde78's Avatar
That picture says it all. GM really couldn't find a way to incorporate the light into the actual heated steering wheel button, and then add a cruise cancel switch where the light is now?
I know that I can tap that brakes, but in every other car I have (all GM) there is a button by my thumb that I can just tap when I am coasting to a stop, see a cop, etc.
Old 04-11-2018, 12:45 PM   #9
trohde78
trohde78's Avatar
You may be on to something! Maybe I can have the heater switch become the cruise cancel switch like your car has...at least during the summer months. haha!
Old 04-11-2018, 12:59 PM   #10
srcstc
First world problems. Brake pedal works as a cancel.
srcstc is offline   Reply With Quote
Old 04-12-2018, 12:38 PM   #11
Kise
Kise's Avatar
im confused...I have a heated steering wheel and I have a cruise control cancel button as well... its the cruise control symbol just below the headed steering option that turns the cruise control on (on as in enabled on dash, just need to press the down button to set it as you would set any cruise control) ..
am I the only one who has discovered this or am I misunderstanding?
Old 04-12-2018, 01:35 PM   #12
trohde78
trohde78's Avatar
Yes, there is an on/off button, but there is no "cancel" button (if you have a heated wheel) that functions the same as tapping the brakes, and retains the previous cruise mph setting.
Old 04-12-2018, 02:23 PM   #13
Kise
Kise's Avatar
ohhh okay. so your concern is when you cancel the cruise control, it doesn't resume your previous speed automatically. makes much more sense. i honestly didn't know cars did that lol
Old 04-12-2018, 02:59 PM   #14
fighting irish
The Doctor is in
fighting irish's Avatar
Drives: 2016 Camaro 2SS Nightfall MRC NPP
It bothers me too. My 16 mile commute is filled with police cars, so I use cruise extensively to avoid a ticket. Not having a cancel button is definitely annoying.
2016 2SS MRC NPP Sunroof Nav, Forgestars CF5V with RE-71r 275/35r19s in front and 285/35r19s in rear
2017 Silverado 1500 LT Z71 Double Cab
2017 Honda Pilot Elite
fighting irish is offline   Reply With Quote
