Old 04-11-2018, 10:20 AM   #1
Krypton1le
Drives: 2017 Camaro SS 1LE Krypton Green
LT4 TMap Scaling
Hello - I posted this in the force induction section, but maybe its more applicable over here.
Does anyone know the Map Sensor Linear and Offset for AC Delco 12644807?
I swapped from the 3bar ls9 sensor to the LT4 TMap sensor so i can monitor boost air temperature as well. I ordered the TMap jumper harness through ADM.
With the 3bar sensor calibration, the Tmap sensor is reading 85kpa at ambient. So, I adjusted the Map Sensor Linear/Offset from 312kpa/-11.25 to 255kpa/-11.25. Ambient read 65kpa.. so it seems I went the wrong way.
I looked through some zl1/zo6/cts-v stock files and it looks like they are running Map Sensor Linear/Offset 425kpa/-32.5kpa. With this I am reading an ambient pressure of 99kpa which sounds good.. but those numbers just seem wrong to me..
I got a response from ADM this morning that the Linear/Offset should be 268.98/-1.65. I have not yet tried these, but I assume it will scale similarly to the 255/-11.25 that I tried previously..
So.. does anyone know exactly what the linear/offset for this particular sensor should be..
Krypton1le is offline   Reply With Quote
Old 04-11-2018, 01:06 PM   #2
DSX Tuning
Drives: 2019 Corvette ZR1
425/-32.5 is correct. Why’d it seem wrong? It’s a four bar sensor.
DSX Tuning is offline   Reply With Quote
Old 04-23-2018, 09:22 AM   #3
Krypton1le
I was under the impression that it was a 2.5bar or 3bar sensor based on information online (such as the below links). I actually ordered the part from ADM (the LSA-Conversions website) where it states that it is a 2.5bar sensor.
https://lsa-conversion-store.myshopi...4-tmap-harness
https://paceperformance.com/i-204526...t4-engine.html
Old 04-30-2018, 03:21 PM   #4
JANNETTYRACING
JANNETTYRACING's Avatar
If you purchased your sensor from Pace and it is the LT-4 sensor, then I provided the correct data for it and the fact that it read 99 Kpa key on engine off is proof your good to go.
I believe Andy sells a similar dimension Tmap sensor that might be a 2.5 bar, you would have to ask him to confirm that.
The part number is the only way to tell them apart.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 05-01-2018, 10:16 AM   #5
Krypton1le
Hey Ted - I was able to get it all sorted out with Andy (since it was purchased through him). Apparently they use a few different sensors so there was some initial confusion with the numbers supplied. Combined with the website listing it as a 2.5bar sensor. All is good now though!
Old 05-01-2018, 12:45 PM   #6
JANNETTYRACING
Glad I was able to help you get it sorted out.
Ted.
