Old 04-10-2018, 04:39 PM   #1
Dethsupp0rt
Drives: None
Limp mode @ 5K miles :(
Decided to take the Camaro today since it was over 40 degrees for once, and on the way home the car goes into limp mode at a stop light.
It wouldn't move at all, so I power cycled the car a couple times and finally managed to get it to accelerate and drive at reduced power.
Got home OK, and put it on the scanner . . . 3 codes related to cam/crankshaft position (P0010, P0016, P2089) and a body code (B2AAA).
I guess there's a dealer visit in my future. :(
Dethsupp0rt is offline   Reply With Quote
Old 04-10-2018, 05:30 PM   #2
CT ZL1
CT ZL1's Avatar
Drives: 2018 ZL1
Is the car stock?
Whats been done to it?
Past Rides
13 Porsche 911 4S
17 BMW M4
16 Shelby GT 350
07 Saleen Mustang
02 M3 Comp Pack
79 Corvette
CT ZL1 is offline   Reply With Quote
Old 04-10-2018, 06:02 PM   #3
Dethsupp0rt
Drives: None
Originally Posted by CT ZL1 View Post
Is the car stock?
Just a CAI, otherwise stock.
Did an oil change < 1,000 miles ago, along with changing the rear diff fluid (before winter, as it's been stored since November other than the very few days it's been nice out). It's been fine up 'til today.
I don't even really get on it . . . no smokey burnouts, no launches, etc. I drive a bit spirited, but not abusive.
Guessing it's just a camshaft position sensor or something. Hope so anyway.
Old 04-10-2018, 06:38 PM   #4
soceur77
Drives: 17 NFG ZL1 17 GTR 22 RS6
and its stories like this that make me wait on any crazy mods that will def get my warranty voided...sucks!!! To the OP hope all turns out well.
soceur77 is offline   Reply With Quote
Old 04-10-2018, 06:50 PM   #5
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Woah, so it is an actual mechanical failure of camshaft/piston or is it a sensor/electrical error? Hopefully the latter or GM will be getting you a new Engine...
If it's not already too late GET THAT CAI OFF juuuuust in case they try to start some BS.
Old 04-10-2018, 07:03 PM   #6
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
Forgive me if I got you mixed up with someone else, but didn't you have a ported TB as well? Not saying that has anything to do with your issue.
torqueaddict is offline   Reply With Quote
Old 04-10-2018, 07:22 PM   #7
Dethsupp0rt
Drives: None
I have one, but it hasn't been installed since last fall. The first one I got threw some TPS codes after awhile, so I got it replaced.
The new one didn't appear to have any issues, but I took the car on a trip with the family in fall and didn't want to risk anything happening, so I put the stock one back on. Was going to put the ported one back on when the weather warms up and I start driving it (nearly) every day.
Old 04-10-2018, 07:26 PM   #8
Dethsupp0rt
Drives: None
I didn't plan on it, but it may not be a bad idea.
Old 04-10-2018, 07:41 PM   #9
Chevyman2
Chevyman2's Avatar
Drives: 2018 zl1
What is the build date month/year?
Chevyman2 is offline   Reply With Quote
Old 04-10-2018, 07:54 PM   #10
Dethsupp0rt
Drives: None
I want to say it's 4/17.
Old 04-11-2018, 03:42 PM   #11
CT ZL1
CT ZL1's Avatar
Drives: 2018 ZL1
I would def put it back to stock if it was me u dont want to give any car manufacturer the opportunity to come up with some bs to void a warranty.
Shit even take out after market mats
Past Rides
13 Porsche 911 4S
17 BMW M4
16 Shelby GT 350
07 Saleen Mustang
02 M3 Comp Pack
79 Corvette
Old 04-11-2018, 04:55 PM   #12
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2019 ZL1 on Order
Defo take off the CAI - not even worth the risk.
As long as you weren't tuned for it should be fine
Modern07 is offline   Reply With Quote
Old 04-11-2018, 04:56 PM   #13
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
Most likely a sensor or loose wire. Have you tried removing the ground wire from the battery to see if the code will clear? Worth a shot
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp
VAZL1 is offline   Reply With Quote
Old 04-11-2018, 05:50 PM   #14
Dethsupp0rt
Drives: None
I cleared the code, it's still not running right.
