![]() ![]() ![]() Drives: 2019 CLA 450 Mercedes Join Date: May 2016
How Do You All Manage the Front Splitter
I am just wondering how you folks manage the length and height of the front splitter? I worry about even small curbs and really wish we had a front camera or front parking sensor.
I bought it to be a daily driver and it is what I want to do. However, entrance and exit from many places is a bit more white knuckled than I would prefer.
2019 Lunar Blue Metallic Mercedes CLS 450
2021 C43 AMG Mercedes Coupe Metallic Cardinal Red 2014 Lincoln MKT EcoBoost (The Bus) |
![]() Drives: 2017 Camaro ZL1 Join Date: Jul 2017
They make front cameras to add to your car. Personally, Ive just kind of gotten a feel for it and if she scrapes a little its usually those cheap plastic airdams under the splitter that take the hit. Ive pretty much come to the conclusion that it is going to get messed up eventually, so I dont stress about it too much.
![]() Drives: 2017 ZL1 A10 Nightfall Gray Join Date: Jul 2017
You may have found my post below after running my splitter into a concrete wall at less than 1mph. It cracked, bent and looks bad and needs to be replaced. The splitter can be had for $200 shipped and it comes painted. The problem is that you have to take off the entire front end to replace it. So that is annoying. The aero bits below the splitter are what I usually scrape, and those are really cheap and easy to replace by just removing a few bolts. Good luck, and park careful!
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
I back into most parking spots using the backup camera to guide me. The only time I pull forward into a spot is when I'm absolutely positive there's nothing in front of it.
In my garage, I use a tennis ball on a rope to let me know how far I can safely pull in.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
I find a spot on the wall for both of my vehicles and use that to stop when it is on the side of me
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
Yup. That generally is my rule. I broke my rule when I decided to parallel park next to a wall with another wall in front and a car behind. Pulled forward to straighten the front out, and went too far. Remember, always back into your parking spot lol.
#7 |
Retired from Car mfrs....
Brandmotion curb alert-installed correctly, they work.
#8 |
![]() ![]() ![]() ![]() ![]() Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
I exclusively back into parking spots with curbing.
#9 |
![]() Drives: 2018 Black ZL1 A10 Join Date: Jul 2016
99% of the time, I back my car into spots. If I can't back-in for some reason, I use the reflection of the car next to me as help or I just leave some space.
Like Jmueller said, the splittler is fairly cheap to replace. It's not ideal, but you could stockpile them if needed.
Current Car:
2018 Camaro ZL1 | Black | A10 | PDR | Nav | Sunroof | CF Hood Insert | CF Instrument Panel Mod List: Corsa Extreme Axle-Back | Borla X-Pipe (#60607) | Roto-Fab CAI | GM Dark Tail Lamps | GM Dark Third Brake Lamp | DD Dark Side Markers | GM CF Fuel Door | Rear Reflector Blackout Kit | Xpel Clear Bra | Modesta BC-08 Ceramic Coat |
#10 |
![]() Drives: Pre-production ZL1 M6 Join Date: Feb 2016
I back into parking spaces or park horizontally like a diphead across two spaces. And when it comes to steep driveways welll... you just have to scrape the #%*+ out of them and keep replacing those rubber air dams, or find a new place or way to go.
#11 | |
![]() ![]() ![]() ![]() Drives: 2018 ZL1 A10 Join Date: May 2012
DAVENPORT STAGE 2 PLUS - 2" ARH ceramic coated headers - 3" ARH catless exhaust - Stock NPP mufflers - Kong ported SC - Katech 103 ported TB - Rotofab 5" Big gulp CAI - 22.5% lower pulley - ATI Harmonic balancer - Cordes SC expansion tank - MSD hi temp ignition wires - Koolsox spark plug insulators - custom tunes - 660hp/725tq pump - 713hp/763tq race
#12 |
![]() Drives: 2017 ZL1 A10 Vert Join Date: Jan 2018
I have a new one in box in the attic waiting for the next Uh-Oh.
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 A10 Join Date: Nov 2008
There is a HowTo to add a CHEAP wifi camera setup to your front bumper.
That's what I did. Just look on your phone...
ZL1::J-E-T-S JETS JETS JETS |
#14 |
![]() Drives: 2018 Camaro ZL1 M6 Join Date: Jul 2017
Got this for the garage. Works great unless you have your front plate on
https://www.amazon.com/Striker-Adjus...+parking&psc=1
3000-9/18/2017 Received-12/1/2017 |
