![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
SS 1LE OEM Brake Rotor Splash Shield
I’m having trouble confirming whether or not the SS 1LE comes with a “track” brake rotor splash shield, like the alternate one the SS comes with (along with the taller control arm deflectors). I am trading my SS for a used SS 1LE and want to know in case I need to remove the track rotor splash shield off of my SS.
Just FYI, to be clear, the “track” SS splash shield is half as big as the regular splash shield and has an added “tag” of metal to cover the tie-rod end from heat. I’ll see if I still have a picture. I believe the GMPP 6-pot kits does include it. |
![]() ![]() ![]() Drives: 2017 1SS 1LE Join Date: Jun 2016
I traded from the SS to an SS 1LE last year and asked the same question. The 1LE doesn't come with the secondary deflector that the SS uses. 1LE is ready to go to the track without swapping anything.
I believe I saw another post somewhere on here that mentioned that you could put the SS deflector kit on the 1LE for extra cooling, though.
2017 SS 1LE.
May have actually answered my own question, but this could still be an interesting point.
The stock SS shields look like the 1st picture (actually off an LT, but they are very similar). The SS "track" shields are the second picture, the GMPP 6-Piston Shields (same as SS 1LE) can be seen in the 3rd picture. The 4th, bottom picture is of RXtacy's SS1LE. Point is, the SS "track" deflectors offer an even closer setup to no rotor shield at all. Also, I've seen on here where the SS "track" control arm deflectors wont work on a SS 1LE due to the ride height. That is not true. The SS "track deflectors do not end lower, past the under fascia aero spats [that the 1LE's don't have]. As you can see from the 1LE picture, there is plenty room. |
#4 | |
SS Track Deflectors on the 1LE:
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
You are confusing the areo deflectors with the brake cooling deflector. What you circled has nothing to do with brake cooling. In fact that piece is to be removed from a standard SS when tracking. What Mountain showed is the SS cooling ducts. His pic clearly shows that is hangs lower than the SS 1LE ducts. They probably would be too low to leave on while street driving.
#7 | |
Nice! No interference with the SS 1LE brake shielding I assume? I was looking at mine the other day and thought the 1LE shield covered a little more of the rotor than the SS track shield, right? I could be wrong, though...
And yes the SS track ducts definitely hang lower than the 1LE ducts. The intent of the SS track duct and minimalist dust shield were to provide maximum airflow to the smaller SS brakes, so they stick down further to deflect more air. I also had an SS for a bit and drove around with the track deflectors on the street. Even though they stick down lower, I never had any clearance issues. They move with the wheels, so the only things you have to watch out for is when you're driving over very uneven surfaces and stuff on the road like roadkill. Bigger objects that both wheels go over like speed bumps were never an issue. Another thing to be cognizant of is that any water and/or road debris kicked up by vehicles in front of you is also potentially being deflected at your brakes. I never had any issues in the few months I drove like that, but still is a possibility for stuff to happen because of it.
2017 SS 1LE.
#8 | |
I circled them only as an indirect indication on how the SS track brake deflectors don’t extend too low as a reasoning why GM doesn’t provide them with the 1LE. I’ve heard people assume this... I posted actual pictures of my 1LE with the SS deflectors as a follow-up, direct example of the installation. |
#9 | |
![]() In respect to running them on the road, I was thinking about this, but I don’t plan to drive the 1LE in a lot of inclement weather or on gravel/dirt roads. However, like you, I had them on my SS all the time and I DD-ed that car spring-fall without issue. EDIT: To answer your questions: No interference with the SS 1LE brake shielding I assume? No, not at all. It is 100% bolt-in. No issues. I was looking at mine the other day and thought the 1LE shield covered a little more of the rotor than the SS track shield, right? The SS track backing plate is more open than the SS 1LE/GM PP 6-piston backing plate. The SS backing plate will, also, bolt right on without issue. I'm not going to swap to the SS backing plate unless I find I need a touch more cooling. The SS track deflectors are a very simple install and I think they will make a larger difference than going from the SS 1LE backing plate. Last edited by Mountain; 05-11-2018 at 12:18 PM. |
#10 |
The kit was only $15 so I thought I would try it out on track. So far just have the deflectors on
#11 |
![]() Drives: 2019 ZL1 1LE Join Date: Feb 2017
Interesting. Part numbers?
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
#12 |
#13 |
![]() Drives: Chevrolet Camaro SS Join Date: Mar 2015
IMO, the track shields look more like ball joint protectors .. designed as heat shields, not rotor shields.
On the C6 vette we found that heat from the rotors were melting the grease boots which eventually would lead to ball joint failure from heat more than dirt. Here is an aftermarket kit designed to protect the ball joints http://www.lapponline.com/index.php?...27mpdoqkevijg5 But again, just my opinion. |
#14 | |
The point is to remove as much coverage as possible, for optimum brake cooling, yet still utilize the radiant heat protection. |
