Old 04-08-2018, 12:45 AM   #1
CT ZL1
CT ZL1's Avatar
Drives: 2018 ZL1
More sound from ZL1 exhaust?
I wanted to get more, better deeper rumble etc from my ZL1 exhaust is there any recommendations besides a new exhaust system?
If not which after market exhaust system do u like?
Thanks
Past Rides
13 Porsche 911 4S
17 BMW M4
16 Shelby GT 350
07 Saleen Mustang
02 M3 Comp Pack
79 Corvette
CT ZL1 is offline   Reply With Quote
Old 04-09-2018, 12:44 PM   #2
soceur77
Drives: 17 NFG ZL1 17 GTR 22 RS6
I started of cutting of secondary cats, and was only a tad louder at WOT. Pulled the fuse, and been happy ever since. Ill get an exhaust eventually but for now im good!!!
soceur77 is offline   Reply With Quote
Old 04-09-2018, 01:04 PM   #3
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Out of the stock exhaust? Pull the fuse to leave it 100% open all the time (Even track mode closes at certain times). Next step would be a secondary Cat delete from and exhaust shop OR a Borla 60606 X-Pipe. If you get a secondary cat delete make sure that the exhaust guys take the entire cat-back out so they get a solid weld over the top or you'll have a check engine light.
A Borla X would bolt to the back of the primary cats, delete the secondary, replace the factory X and crushed rear section, and you'd have to cut the stock cat-back just in front of the factory suitcase muffler. Personally that's the route I'd go if not going for a full exhaust/cat-back.
Next up would be an actual muffler system and for me, there's only one name worth using and that's Corsa. I think I'm going to go Corsa Axle-back + Borla 60606 X-Pipe for a full-cat-back since Corsa doesn't make an X pipe for the 6th ZL1.
Old 04-09-2018, 01:42 PM   #4
Tampabucs4
Tampabucs4's Avatar
Drives: 2018 blue ZL1
Is the 60606 3inch?
Tampabucs4 is offline   Reply With Quote
Old 04-09-2018, 01:43 PM   #5
harrist5683
harrist5683's Avatar
Drives: 2018 Black ZL1 A10
I went the Borla x-pipe -> Corsa Extreme route. I don't think you'll have any regrets. Personally, it's the best sounding combination I've heard on a 6th Gen.
As to the OP: the NPP fuse pull and/or a secondary cat delete are your best/only options. If you want a true change in tone without it sounding cheap, you'll have to go aftermarket.
Edit: To add, I've had a Borla ATAK system on a 2016 2SS, and the Corsa Extreme is 1-tier higher in my opinion.
Current Car:
2018 Camaro ZL1 | Black | A10 | PDR | Nav | Sunroof | CF Hood Insert | CF Instrument Panel
Mod List:
Corsa Extreme Axle-Back | Borla X-Pipe (#60607) | Roto-Fab CAI | GM Dark Tail Lamps | GM Dark Third Brake Lamp | DD Dark Side Markers | GM CF Fuel Door | Rear Reflector Blackout Kit | Xpel Clear Bra | Modesta BC-08 Ceramic Coat
harrist5683 is offline   Reply With Quote
Old 04-09-2018, 01:57 PM   #6
RedHot18
Drives: 2018 ZL1
Borla cat back Attack kicks ass
RedHot18 is offline   Reply With Quote
Old 04-09-2018, 02:03 PM   #7
harrist5683
Originally Posted by Tampabucs4 View Post
Is the 60606 3inch?
2.75 as listed on the Borla Site. They have an adapter (60625) used to attach to 3inch headers.
Current Car:
Mod List:
Old 04-09-2018, 03:34 PM   #8
CT ZL1
CT ZL1's Avatar
Drives: 2018 ZL1
Do u know what fuse number u pulled?
Past Rides
13 Porsche 911 4S
17 BMW M4
16 Shelby GT 350
07 Saleen Mustang
02 M3 Comp Pack
79 Corvette
Old 04-09-2018, 08:26 PM   #9
Bill_76
Drives: Camaro ZL1 2018
51
Bill_76 is offline   Reply With Quote
Old 04-09-2018, 09:24 PM   #10
mdmoore23
mdmoore23's Avatar
Drives: 2017 ZL1
Kooks axleback was very surprising for me. I went out on a limb and bought it since the price was lower than most. The car has a much deeper rumble. Here's a short cold start video of mine. Use headphone to get a real feel for it.
https://youtu.be/LM8Rkb9na8k
mdmoore23 is offline   Reply With Quote
Old 04-09-2018, 10:33 PM   #11
Zl1+911
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10
Which option
Seems like a good price. Which exact option did you get? Muffler delete ? Thx
Zl1+911 is offline   Reply With Quote
Old 04-10-2018, 11:21 AM   #12
mdmoore23
mdmoore23's Avatar
Drives: 2017 ZL1
I got the one with the mufflers. It was the exact sound I was looking for. Just keep in mind you will lose dual mode, and drone is definitely increased at certain cruising speeds. It's all worth it to me though. I paid about $620 for the axleback through a WeaponX sale.
Old 04-10-2018, 11:23 AM   #13
Can'tHave2MuchHP
Drives: Fast
I would be careful with the Kooks, if you can't stand drone then don't buy it. Corsa doesn't drone. Borla claims it doesn't either.
Old 04-10-2018, 12:40 PM   #14
Tech@Flowmaster
Tech@Flowmaster's Avatar
Drives: 2016 Camaro SS
Thanks
You can do a simple muffler replacement to get a deeper or more aggressive exhaust note. This route saves money because the stock exhaust piping is utilized, not replaced. Keep in mind when going this route you will have to have the stock exhaust tips welded onto the new mufflers.
We offer a number of Cat-back, Axle-back and Universal Mufflers for the 6th generation Camaro. Feel free to give us a call at 707-544-4761 and speak with one of our Support Team members. Just let us know what exhaust note you prefer and we'll give the best options for your ride. You can also get your Camaro6 forum discount when you call.
- Jason @ Flowmaster
Tech@Flowmaster is offline   Reply With Quote
