Old 04-06-2018, 12:59 AM   #1
Gen5&Beyond
Gen5&Beyond's Avatar
Drives: 2016 2ss Camaro
Underdrive Pulley?
Anyone using a underdrive pulley?
HBM 2016 2SS A8 NPP
427 Pray Head/Cam/Converter, Pray Ported Highram, 103mm TB, Pray Tuned, 3030 Drag Pack, Roark OTR CAI, TSP Headers, E85, UDP
Best times 1/4 n/a 9.23@146.96, 1/8 5.91@118
Gen5&Beyond is offline   Reply With Quote
Old 04-06-2018, 01:09 AM   #2
ULTRAZLS1
ULTRAZLS1's Avatar
There’s a few
What you want to know?
Old 04-06-2018, 03:27 AM   #3
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
are you cammed? because there is no need for one unless your RPM is over 800. they dont free up power. They are meant to slow your steering pump and alt down with the higher rpm.
Old 04-06-2018, 08:11 AM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
62nalide said they seen over 10whp with ATI balancer.
Old 04-06-2018, 08:40 AM   #5
ZNix
Drives: 1987 Buick Grand National
10whp for 450 is actually not bad at all... Adding to my list.
ZNix is offline   Reply With Quote
Old 04-06-2018, 09:11 AM   #6
ULTRAZLS1
ULTRAZLS1's Avatar
I got one now. We’ll see if I gain anything at the track
It’s 3 lbs lighter than the stock and is 10% underdrive. There’s no power steering pump or pulley on these cars btw. Electric power steering.
While they do claim to stabilize better at high rpm that’s not the only benefit. The slightly smaller pulley makes everything easier to turn. Being lighter is less for the crank to spin as well. It should free up some hp
Just don’t use the arp bolt
http://www.camaro6.com/forums/showthread.php?t=524649
Old 04-06-2018, 09:40 AM   #7
Snowblind
Snowblind's Avatar
Old 04-06-2018, 03:28 PM   #8
ZNix
Has anyone checked out the Innovators West unit? Looks to be even lighter.
Old 04-07-2018, 10:43 PM   #9
Gen5&Beyond
There’s a few
Just wondering what kind of gains everyone was seeing. Is it worth the cost?
HBM 2016 2SS A8 NPP
Old 04-07-2018, 10:50 PM   #10
Gen5&Beyond
Great! Let us know what you think.
HBM 2016 2SS A8 NPP
Old 04-07-2018, 11:15 PM   #11
TJay74
Sometimes the cost versus the gains are not the greatest, but in the end its the sum of all those small gains that starts to make it worth while if you are chasing for good bolt on horsepower.
Old 04-07-2018, 11:41 PM   #12
ULTRAZLS1
ULTRAZLS1's Avatar
Well a couple people that have dyno them claim they are worth over 10 rwhp. That’s hard for me to believe. I would guess like 7-8. But hey maybe it true idk
I have messed with the tuning and conditions won’t be the exact same to compare from before. The car doesn’t feel slower is all I know lol
Hope I can make it out next weekend. Check the drag section
100% correct. I got a lot of little things on my car most would say not worth it. But in the end they not as fast as me lol
Old 04-08-2018, 08:46 AM   #13
KingLT1
KingLT1's Avatar
Yep...it's always those last few horsepower that have the worst cost vs hp ratio.
Old 11-06-2018, 11:21 AM   #14
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
How is the long term of this? My old car, an frs, if you did a lightweight crank pulley or other pulleys, it added extra wear on the crank bearings as there wasnt enough weight to counter balance it. That is on a boxer motor which has less harmonic vibrations (is that the right term) than a standard v engine setup. They actually use a heavier aftermarket crank pulley. Could this happen with our engines as well, or since the engines are different it's hard to compare?
