Old 04-03-2018, 11:01 PM   #1
The_DarkKnight
Drives: 2018 ZL1 1LE
What kind of magnetic drain plug do I buy?
changing oil soon, which one?
The_DarkKnight is offline   Reply With Quote
Old 04-04-2018, 12:00 AM   #2
waterman
waterman's Avatar
Drives: Grandad's C2 L89
I like Dimple, well engineered and extremely strong magnet.
I use Black Holes on my filters as well. I'm blown away by how much particulate that they hold in the filter.
I have a Dimple plug for the first change on my ZLE. Black Holes for the filter as soon as it gets home. Some extra insurance for break in.
2018 ZL1 1LE sw/PDR
Old 04-04-2018, 08:37 AM   #3
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
I have dimple as well on my Z06, and will do the same for the ZL1 1LE. My Z06 has 2 oil drain plugs that are dimple, the black holes on the filter and a drain and fill plug from dimple on the trans and the rear.
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 04-04-2018, 10:25 AM   #4
wlsmoku
Drives: 2018 ZL1 A10
I haven't changed the oil yet on the ZL1, does it not come from the factory with a magnetic plug, or is the Dimple just a stronger magnet?
wlsmoku is offline   Reply With Quote
Old 04-04-2018, 12:10 PM   #5
chicagosam
chicagosam's Avatar
Drives: 2017 BLACK ZL1 A10
Anyone know the size of the plug?
M12x1.75x21 or 1/2"x20x1/2"?
'17 Mosaic ZL1 Katech TB, Plugs/Wires, Rotofab Oiled,+18% Lower, 2" Headers, Cat Delete, 93 Tune, Mobil 1, IPA FF04, 315/30/20 r888r, 664hp/693tq (93), 702hp/727tq (100 oct)
chicagosam is offline   Reply With Quote
Old 04-04-2018, 12:11 PM   #6
k20attack
k20attack's Avatar
Drives: 2018 Camaro ZL1 M6
pretty sure it's M12x1.75. Found that somewhere else in the forum.
3000-9/18/2017
Received-12/1/2017
k20attack is offline   Reply With Quote
Old 04-04-2018, 12:26 PM   #7
chicagosam
chicagosam's Avatar
Thanks K20, will order a dimple tonight.
Old 04-04-2018, 01:26 PM   #8
k20attack
k20attack's Avatar
Just ordered mine too after seeing this post haha!
3000-9/18/2017
Received-12/1/2017
Old 04-04-2018, 02:02 PM   #9
Outahand
Drives: 2018 ZL1
Don't bother ordering the one for the rear end. My car came with magnetic fill and drain plugs on the rear diff.
Mark E.
2018 ZL1 NGM A10
87 Grand National. Modified Hot Rod for sale *SOLD*
87 Grand National. Stock
65 Olds Vista Cruiser wagon Grand National motor/tran
66 Bronco Rockbuggy
2006 Dodge 2500 4x4 Cummins 6 speed
Outahand is offline   Reply With Quote
Old 04-04-2018, 03:54 PM   #10
cwebster
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6
Thanks for this suggestion. It prompted me to do some digging. During my first oil change in early 2017 I discovered that my LT4 motor didn't come with a magnetic drain plug so I bought this one from Amazon: [LT1 LT4 Magnetic Oil Drain Plug NEO Magnet $12.99]
When I had a tough time pulling my drain plug off the work bench I was happy with my choice but now I'm wondering if the Dimple is better. Both are made with neodymium, a "rare-earth" element. However, there are various grades and temperature ratings of magnets made with this material - some stronger than others.
Neither the one I bought from Amazon nor the Dimple give the exact grade or temperature rating of the magnets in their plugs. The Amazon plug implies in the description that it will pick up a 2 lb wrench and says it's "5X more powerful than GM" drain plugs. Dimple says theirs are "the strongest high temperature grade neodymium magnets in the world". They also say "Dimple's® Black Hole High Temperature Magnets are rated at over 300 degrees." That would be EH grade or better but what about their drain plug magnets?
According to my references, the strongest grade is N52 and the highest temperature rating is EH. However, you can't get a N52EH magnet because the properties are derived from the proportion of materials and methods of production. The highest grade you can get for the highest temperature rating of EH, for example, is N38EH.
Temperature ratings range from standard (no rating)=175°F to EH=392°F. LT4 engine oil temps are normally 195-200°F but Corvette (dry sump) LT4s have seen 230-240°F in stop-and-go traffic. On a road course I'm guessing sustained loads could bring it much higher. I'm thinking we'd need either H=248°F or SH=302°F to be safe. So, the strongest "Neo" magnets for these ratings would be N48H or N45SH, respectively.
I've left questions about grade and temp ratings for Midwest Corvette who sells their plugs on Amazon and for Dimple on their web site.
[Update] Dimple responded right away. Their plugs are all N48SH. That's very strong and capable of maintaining strength up to 302°F.
From what I've read and the commercial and independent videos I've seen, I'm inclined to believe that Dimple does make the strongest, most temperature tolerant magnetic drain plugs. I've always believed that a good magnetic drain plug will keep oil clean longer and extend the life of the components in which they're installed. I'll be ordering replacements for mine for the next oil change.
Looks like this one is for all LT1 and LT4 motors. Probably fits the V6 too.
$34.95 M12x1.75x21 Magnetic Drain Plug for GM
I'll definitely be getting these too:
$34.95 4-Pack of Super Black Hole Engine Oil Magnets
Can you give me a link for the ones you used on your transmission and rear differential? I'm wondering if they'll fit the TR6060 M6 and diff sump on the ZL1s. I didn't see anything other than engine oil plugs on the Dimple site for GM/Chevy/Buick.
Mine was built during production week 12/5/2016 and DID NOT come with a magnetic drain plug in the engine. However, both drain and fill plugs for the TR6060 M6 and the rear differential did come with them.
--Cal
References:
Dimple Motor Oil Magnets
Neodymium Magnet Information
Neodymium Wikipedia Article
cwebster is offline   Reply With Quote
Old 04-04-2018, 03:59 PM   #11
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Scale of 1 to 10 how much is something like a magnetic oil plug really going to do for your engine? If it's big enough to do damage, the chances of a small magnet holding it are probably not good.
Old 04-04-2018, 05:01 PM   #12
cwebster
Cal
I'd have nothing to compare with in a 1 to 10 scale. I guess I'm looking at it from a different perspective. I'm not trying to protect against chunks. That would signal some kind of severe or catastrophic damage. Still, it would be nice to detect larger particles before a catastrophic failure occurs.
Removing the fine metal particles before they circulate through the engine seems to me like just good preventive maintenance - less to clog the filter and less wear and tear on moving parts. $35 doesn't seem like a big expense to me to keep this "normal" debris out of the oil.
--Cal
Old 04-04-2018, 05:04 PM   #13
Ryanbabz71
Ryanbabz71's Avatar
I have always run them on my vehicles. It catches some good stuff on my truck. I wil have to find a photo of my last oil change and post.
Ryan
Old 04-04-2018, 05:42 PM   #14
Ryanbabz71
Ryanbabz71's Avatar
Ryan B.
Ryan
