Old 04-02-2018, 11:23 AM   #1
Razor427
Drives: 2016 Camaro 1SS
Lt1 with lash cap = lt4 pump
Is the LT1 pump with a 8mm lash cap equal to a LT4 pump?
Ray
Razor427 is offline   Reply With Quote
Old 04-02-2018, 11:34 AM   #2
boostednut
Drives: Nothing cool atm
Short answer until someone else who know's the specifics is no. The peak pressure I believe in ecu is higher on the lt4 pump, and some kind of pump internal difference. But I think you're asking in terms of functional flow...
I'm unsure about what lash cap you can run in what situation, because I do understand that if you run the wrong lash cap, and the pump doesn't mount correctly you'll break the pump off. So... running a cap on stock cam is something I don't fully understand.
Hopefully someone can clear up the details/provide more info on a stock lt1 pump and stock cam can (with a lash cap). It seems to be the least discussed, probably because most places won't make any money off selling a lash cap.
boostednut is offline   Reply With Quote
Old 04-02-2018, 11:49 AM   #3
62nalide
62nalide's Avatar
Drives: 2013 SS
that's a big NO
62nalide is offline   Reply With Quote
Old 04-02-2018, 03:16 PM   #4
Razor427
Check this out.....
https://www.corvetteforum.com/forums...learances.html
Old 04-02-2018, 03:38 PM   #5
parish8
Drives: 17 SS a8
Originally Posted by Razor427 View Post
There is some solid info in that link but it implies a lash cap on just a lt1 pump with stock cam will add fuel. I don’t see how this would be possible.
Read that entire link to get an idea of how things work. Then read this: a stock lt1 pump has preload on it from the factory. Installing a lash cap will only move the piston up higher in the stroke. It will not increase the stroke.
Old 04-02-2018, 08:51 PM   #6
JFM-jr
JFM-jr's Avatar
I agree and I started a thread over there a few weeks ago asking about how the cap increases pump output with no additional stroke. I was told its where the cap moves the strokes operating range. It relocates the operating range to a more optimal zone. I of course asked if anybody has solid data to back this up and there is none. So its still speculation in my book.
Heres the short thread I started
https://www.corvetteforum.com/forums...-lash-cap.html
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 04-02-2018, 10:21 PM   #7
parish8
Drives: 17 SS a8
Without data of some kind there is no reason to believe that. I can tell you for sure a stock cam and lt1 pump has some preload from the factory and that pump is going to see the entire stroke from the cam lobe. I tested it myself.
Old 04-03-2018, 11:01 AM   #8
boostednut
Yes in theory putting a cap on it won't change the stroke distance. Just the start and end heights. So that's what I don't get.
I'm imagining that you use a smaller lash cap, so that you can increase the preload distance. Depending on how the pump is designed this could potentially increase fuel volume per stroke.
But I've yet to see anyone actually explain this. Everyone talks about lobe and lash. But nobody explains this pump specifically in relation to stroke distances. It's curious.
Old 04-03-2018, 12:28 PM   #9
JFM-jr
JFM-jr's Avatar
From what I was told and the way I understand it it's exactly as you describe. It moves the starting and ending points of the stroke in closer towards the body of the pump. The theory is this area of stroke moves more fuel than the stock area of stroke without the cap. Again unproven without supporting data.
Rotofab
11.0@124.9
Old 04-03-2018, 12:45 PM   #10
boostednut
It's potentially true. But it's just as possible to not do anything to help flow.
Would be nice to see this answered one way or the other. It's pretty simple and should be repeatable.
Old 04-03-2018, 01:32 PM   #11
parish8
Drives: 17 SS a8
My money is on no change in flow.
Old 04-03-2018, 09:44 PM   #12
JFM-jr
JFM-jr's Avatar
and im not taking that bet
Rotofab
11.0@124.9
Old 04-03-2018, 10:45 PM   #13
boostednut
Either way there's no excuse to not have any real world info or data on it. Like all it takes is one person to have actually done it to mean anything
Old 04-04-2018, 08:57 AM   #14
parish8
Drives: 17 SS a8
What are you waiting for?
