![]() Drives: C3 Join Date: Feb 2016
ZL1 PDR ?
Well first my A 10 had a trans line leak, and now the PDR does not work.
Ive owned a C7 and 17 1LE with PDR. I Kept my scan disc 32GB 10 card that worked perfect I had in the 1LE. No dice in the ZL1 when I tried it the 1st time today. Gives me the no card or insert card BS. I said what the heck and formatted it quick and long, and it works perfect in my camera's. Still wont work in PDR. Then tried my micro card with adapter from my Garmin Virb which is the same 32GB 10, it wont work either. ![]() Any other ideas, or is it time for the dealer to try to figure it out. Thanks Dale |
Maybe not even getting a signal from the hub or card insert slot.
https://gm.oemdtc.com/1281/performan...rolet-corvette |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
That’s why I didn’t want PDR. One less thing that can fail.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
Worked perfect in both my other cars, we will see what they can find.
Just spent a couple hours at the dealer. After diagnostic this and that with the reader to computer, we pulled the car reader hub from the dash.
Sure enough some idiot at the factory left one plug out of two disconnected. I cant believe they dont do a quick test of these components, since there was in fact a code thrown. Its all fixed and works fine now D |
Good to hear you got it resolved.
