Old 03-30-2018, 08:04 PM   #1
brettman
Drives: 2016 Camaro SS
Lt4 fuel components before re-tune
Looking to install LT4 injectors and HPFP. then drive an hour to re-tune and dyno.
Will it run safely, or does it need to be flat bedded.
Everybody I talked to does all at the same time, in a shop.
So unknown if it can be driven. I prefer to do the install myself.
I need to remove the SC, for other work that needs done.
Does anyone know.......Thanks
brettman is offline   Reply With Quote
Old 03-30-2018, 09:22 PM   #2
JFM-jr
JFM-jr's Avatar
fuel injector scaling will be off I doubt it will run.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 04-16-2018, 09:27 AM   #3
L78toLT1
L78toLT1's Avatar
The biggest p.i.t.a. by far is the in tank pump. I know you can at least do this ahead of time
Baby Blue
