Old 03-30-2018, 04:03 PM   #1
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
Pcv part number
Anyone know the pn of the pcv on the valley cover? The one under the intake that you hook your catch can in to
The nipple piece separated from the rest of it. I'd jb weld it but idk if anything fell out
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 03-30-2018, 04:28 PM   #2
jreagle56
jreagle56's Avatar
Drives: 2022 2SS A10 NPP MRC Red Hot
i just bought one from a gm parts supplier online. They gave me a 12631624. Couldnt change it and verify it with the old part though; i dont have the right size deep well socket......
just for giggles i also bought the factory tube; seperated the Q.D. connectors and used them on the rubber hoses on my elite E2 catch can to make the hoses quick disconnect. Didnt test drive yet; although not expecting any problems
jreagle56 is offline   Reply With Quote
Old 03-30-2018, 04:36 PM   #3
brettman
Drives: 2016 Camaro SS
JB Weld?? Did you break it? You have to 90 degree it. You should have the OEM
Hose that came off it. Just remove the straight fitting and install the 90
brettman is offline   Reply With Quote
Old 03-30-2018, 04:55 PM   #4
Dubchitts
Dubchitts's Avatar
I'm using the oem fitting. I got the standard elite catch can. It didn't come with a 90
"Spitfire" 427ci
Old 03-30-2018, 05:10 PM   #5
brettman
OH, should have posted that, I have some 90's.
And I thought you had a Elderblock....Oh well...lol
Old 03-30-2018, 05:24 PM   #6
Dubchitts
Dubchitts's Avatar
No prob lol. But it's the car side that's separated. I need to get some longer hose for it tho and some nicer clamps the ones that came with mine were weak and I could hear a vacuum leak around them
"Spitfire" 427ci
Old 03-30-2018, 05:38 PM   #7
brettman
Do you need a 90? Will that help with your app?
Old 03-30-2018, 05:45 PM   #8
Dubchitts
Dubchitts's Avatar
It might. Lol
"Spitfire" 427ci
Old 03-30-2018, 05:49 PM   #9
brettman
It might. Lol
It's in the top pic.......take it...lol. I'll dig it out tomorrow, PM you for your address again.
Old 03-30-2018, 06:52 PM   #10
brettman
I just realized, you should have the OEM hose on there, with a 90 degree fitting.
Same as first pic. Were are you tapping in for case vent? (under the intake manifold, front, left side?) You don't need the 90.
PM me.
Old 03-30-2018, 07:22 PM   #11
Dubchitts
Dubchitts's Avatar
This is what's going on
"Spitfire" 427ci
Old 03-30-2018, 07:49 PM   #12
brettman
Oh, that looks broke, $5.00 fitting (valve)
Old 04-01-2018, 10:16 AM   #13
Dubchitts
Dubchitts's Avatar
Thanks for the part number! Got one ordered through my local dealer
"Spitfire" 427ci
Old 04-02-2018, 10:12 AM   #14
Dubchitts
Dubchitts's Avatar
So once I noticed this was broken I babied the car over to my dad's garage for it to wait for that valve, and have the oil changed. The car ran fine the whole 15 miles trip. But once I got out to open the garage door I looked back and noticed there was a little blue smoke coming from my exhaust. I quickly got the car in and shut off.
With the pcv valve not functioning as it should, I'm sure it built up pressure. I didn't see any oil leaking out of the front seal or anywhere else, although it's the break in oil with only about 400 miles so it's still "gold". I'll give it a good look over again.
My question is, do you think I damaged the valve seals, or do you think it was just some blow by into the pistons. I did not notice any smoke on the 15 miles drive, only when I idled to open the door. If it was just blow by burning, should I be concerned or will I be alright as long as it stops smoking after the new valve goes on. If it's blow by I expect a little smoke to finish burning off what's in there, but how long should I give it?
"Spitfire" 427ci
