Old 03-30-2018, 09:00 AM   #1
jeportera
jeportera's Avatar
Drives: 2016 Camaro SS A8
Exhaust Question - Kooks to Speed Engineering
Good morning everyone! I'm in the process of buying some kooks headers and wanted to install the speed engineering x-pipe at the same time. My question is this, do I need to buy the kooks off road connection pipes or will the speed engineering piece include that?
2016 2SS, Borla ATAK, Kooks LT's, Rotofab dry, Pray IM/TB, Pray STG2 blower cam setup, Circle D convertor, Nitto 555rs
jeportera is offline   Reply With Quote
Old 03-30-2018, 10:19 AM   #2
marknagy13
Markoon13
marknagy13's Avatar
Drives: Camaro 2SS
You need the connection pipe, otherwise there will be a gap where the cats should be.
marknagy13 is offline   Reply With Quote
Old 03-30-2018, 11:07 AM   #3
DapperDan
DapperDan's Avatar
Drives: 2017 1SS A8 Nightfall Gray
I'm would like to do this also but am thinking you still are going to need some kind of way for them to mate up I believe kooks pipes are 2.75 and the speed engineering x pipe is 3"
DapperDan is offline   Reply With Quote
Old 03-30-2018, 11:21 AM   #4
LARMEDIC
LARMEDIC's Avatar
Drives: 17' 1ss
I’m in the process of doing this. Per Kooks you need this connection https://www.kooksheaders.com/exhaust-pipe-14149.html . It’s made for a 10-15 Camaro but will work for this application. Two options, cut flared end off of the speed engineering connections and then weld it to the Kooks connections . Or leave the flared end on the speed engineering x pipe and cut down the Kooks connection if room allows, both ways will need a little trimming to fit. This is for a off road set up, I’m sure they may have a catted set up like this too or they can make it.
87' IROC A4 what a car to have at 15 sold
93' Z/28 FBO M6 sold
00' SS H/C/I , 4k yank stall, 100hp TNT N20 sold
10'SS H/C/I M6 sold
12' C6 GS M6 H/C/I , A&A TI Trim ,15" Billet Specialties, 880 RWHP with 109 & meth. 9.70s @ 146 sold.
17' A8 1SS NGM stock for now
LARMEDIC is offline   Reply With Quote
