![]() Drives: 2016 SS M6 Join Date: Mar 2018
Tire size with stock rims SS
I won't need new tires for quite some time, but I have the stock goodyears and the grip is nothing crazy.. Therefore, I would like to upgrade with a larger size tire along with a better tire overall.
So yeah how wide can I go without issues and what are you guys running on your SS with the stock rims? Thanks! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 Garnet Red 1SS Join Date: Mar 2014
255/40 front and 285/35 rear best fit for the stock size wheels. Michelin Pilot Sport 4S are good.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
Markoon13
Drives: Camaro 2SS Join Date: Oct 2016
Fronts are 8.5" wide so a 255 would be about the limit. Rears are 10" so 295s are fine.
Rears are 9.5"
'16 Camaro 1SS
Markoon13
305s will work too.
'16 Camaro 1SS
#7 |
#8 |
'16 Camaro 1SS
#9 |
#10 |
yeah thanks I was going to pick up the 4S tires once I upgrade, but by that time something out might surpass them. If 295's have 0 issues I will go with those, but has anyone experienced the 295 size on the stock rims?
#11 |
Max I will go is 285 on stock rear wheel.
2020 ZL1-1LE A10
2016 2SS A8 (SOLD) |
#12 |
You planning on keeping the stock tires for 7 years? It took Michelin that long before replacing the Pilot Super Sports with the P4S.
'16 Camaro 1SS
#13 |
![]() Drives: White 2018 camaro ss Join Date: Dec 2018
#14 |
![]() ![]() ![]() Drives: 2019 zl1 6 speed Join Date: Jul 2017
You can do 295's but only with a select few tires because of the differences in the widths of each manufacturer. Idk if I said that right, lol, but discount tires, in there system, says it's safe to run 295's ps4's on the stock rim.
