03-28-2018, 02:48 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Mar 2018
Reduced Engine Power
I keep getting Reduced engine power when I stomp on the accelerator pedal, is the problem that there might be a dead spot in the pedal that needs replaced or the throttle body? I have 109,400K miles.
03-28-2018, 02:59 PM | #2 |
Drives: 2012 camaro 45th 2ss/rs Centri SC Join Date: Nov 2016
Did it set a code?
Jeremy
-2012 Camaro SS 45th M6-Kraftwerks Supercharger -2003 Avalanche z71-6" on 35's. DD 290k miles -66 mustang fuel injected resto-mod |
03-28-2018, 03:03 PM | #3 |
Drives: 2012 camaro 2ss Join Date: Jun 2017
Do you have traction control on?
03-28-2018, 03:19 PM | #4 |
Instagram: Sangstah
Do you have a throttle controller?
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
03-29-2018, 03:24 AM | #5 |
Code
The code was P2135 Throttle/Pedal Position Sensor/Switch A/B Voltage Correlation
Yes I had ABS and traction control on and no, I have no throttle controller. After 10 min with the engine off I turn the car on and it goes away, the next day If i drive a couple of miles and the code disappears and gives me a message historic fault. |
03-29-2018, 07:22 AM | #6 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
the pedal assembly may need replaced it has a potentiometer in it to delay response from the input so you get better mileage and don't loose traction. Try disconnecting and reconnecting the pedal and see if any of the connection s have any corrosion and clean connections first. Also hope you are keeping it maintained and have done a deep engine cleaning and throttle body cleaning and maf cleaning.
03-29-2018, 03:35 PM | #7 |
Drives: 2012 2SS Victory Red with white st Join Date: Jun 2016
Check all the wiring on the side of the throttle body . Make sure there are no wires, pinched, burnt, loose, likewise
03-30-2018, 03:21 AM | #8 |
Wires
I did that already and checked the wires on the throttle body and found nothing wrong but what I've noticed when I turn the key to the on position the throttle flap makes a loud grinding noise, I don't know if that's a normal sound. I guess the only thing to do is first replace the accelerator pedal and if that doesn't help the throttle body is next.
03-30-2018, 06:59 AM | #9 |
Drives: 2010 1SS Join Date: Aug 2015
Time to order up a PTB..
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
03-30-2018, 01:57 PM | #10 |
Drives: 2013 Camaro Dusk 2SS/6 Join Date: Sep 2013
03-30-2018, 04:06 PM | #11 |
I think so too, Thanks everyone.
