03-26-2018, 07:52 PM | #1 |
Drives: 2013 SS Join Date: Mar 2018
Trunk Sound deading install
Just finished installing about 78 square feet of Noico 80 mil. in my trunk, rear deck, and the rear interior. It was a longer project than expected, but it got easier as time went on. In total I had the car apart for just under a month. I went for near full coverage in the trunk and rear deck, and did spot coverage when I was putting the interior back together.
https://ibb.co/album/gQSb0a I have a lot of pictures from the process if you're curious on anything. |
03-26-2018, 08:36 PM | #2 |
Nice job! Very thorough. How was it to cut & lay ? What did you use to cut it?
03-26-2018, 08:40 PM | #3 |
Cutting was simple with a box cutter and a cheap pair of scissors. I used a heat gun and took a small roller, tennis ball, or finger tips for the tight spots.
03-26-2018, 09:55 PM | #4 |
Drives: 2015 2LT RS Convertible Join Date: Dec 2016
What was the material cost?
Did you take a before decibel reading so you can compare to an after reading? Just wondering how much benefit you got. |
03-27-2018, 04:49 AM | #5 |
Good to know. I hadn't heard of Noico 80 mil before your post. Saw a Utube review of it by a guy who used to be a car electronics installer who says it's as good as Dynomat, actually a little thicker and cheaper.
03-27-2018, 06:55 AM | #6 | |
2x 36 square foot pack - $63.99 1x 10 square foot pack - $22.40 Sorry, I don't have any measurements before I started. |
03-27-2018, 02:06 PM | #7 |
Thanks for the cost info. Please let me know how much difference it makes inside the car As far as deadening the road noise.
03-28-2018, 09:11 PM | #8 |
I got the sub installed today.
https://ibb.co/n2To4n I might get it on the road Friday to take some measurements of road noise, and again in a month or so after the exhaust change is done. |
03-31-2018, 06:38 AM | #9 |
Drives: 2014 1ss camaro Join Date: Jul 2017
I bought an 18 ft. x 12inch roll of frost king duct insulation for around $ 20 bucks at lowes. self adhesive and about an 1/8 inch thick foil backed foam.
04-03-2018, 05:55 PM | #10 |
ILSQ
Drives: '13 2SS/RS Join Date: Feb 2017
Sweet! Same thing I used, then I topped it with adhesive backed closed cell foam. I also threw some denim insulation in the rear quarter panel spaces. I used Noico and Soundskins door kit on the doors. Very nice products.
Way too many mods to list, and just getting started...
07-25-2018, 11:27 AM | #11 |
H-Town Camaro Club
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP Join Date: May 2014
Sno approves Noico
07-25-2018, 01:55 PM | #12 |
ILSQ
07-25-2018, 04:15 PM | #13 |
Drives: 2018 2SS M6 Redline Join Date: Oct 2014
Dang OP, you went all out. You know that all you need is 25% coverage to be effective right? Anything more than that is just added weight and a waste of money IMO.
07-26-2018, 07:39 AM | #14 |
H-Town Camaro Club
Toe in water, but thank you!
