Old 03-25-2018, 09:48 PM   #1
Nabush
Drives: 2017 C7 GS M7 / 2017 Camaro SS 1LE
Safe Lamdba for LT1 (CAI/Headers)
Guys,
It's for my vette but the same engine as your Gen6 SS, and there are more technical ressources here than in the Corvette forum
I just installed my American Racing headers and my AFE CAI on my 17 GS.
I also bought a wideband O2.
I'm running 13.1-13.3 AFR at WOT with the stock tune and 91 Chevron (probably close to 10% Ethanol)
Edit : After calibrating my probe, I run 0.88-0.89 Lambda = 12.5 AFR with E10 I probably have in the tank
Are my AFR safe to drive the car at WOT ?
I should receive my MSD Intake manifold in around 10 days and then planning to do a tune (dyno tune at JDP Motorsport, UT)
I'm also considering buying DiabloSport Intune 3 as it also to change fuelling and do custom tuning in the meantime if for you I'm too lean.
Thanks a lot for your help on that
Nabush is offline   Reply With Quote
Old 03-25-2018, 09:57 PM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Sounds a little lean. Ime you want to be around 12.8
Old 03-25-2018, 10:04 PM   #3
Nabush
Yeah I recall most dyno graphs I saw were a little bit below 13... but saw one or 2 just a little above 13...
Old 03-27-2018, 12:04 AM   #4
Poppacapp
Drives: 2017 Grand Sport
Originally Posted by Nabush View Post
Guys,
You are a little lean. Try to stay out of the throttle until you get the tune.
17' Grand Sport
PP ported MSD IM, NW 103mm TB, ARH 2" headers w/ 3" catted x-pipe, PP Flex Fuel tune, Halltech CAI, some radials and a CATCHCAN!!!
Poppacapp is offline   Reply With Quote
Old 03-27-2018, 05:33 AM   #5
laynlo15
Drives: 2022 Lt1 A10
12.2 to 12.5 would be a better number for your AFR
Old 03-27-2018, 11:39 AM   #6
dotfiles
@SS_1LE
Drives: 2017 SS 1LE
Why not just drive it conservatively until you get your MSD and custom tune? Should be fine at partial throttle but sounds a bit lean at WOT.
17' Camaro SS 1LE | PDR | Summit White
Borla S-Type Axleback | Mishimoto Catch Can | LED Sidemarkers | ZL1addons DRGs | Michelin MPS4S
dotfiles is offline   Reply With Quote
Old 03-27-2018, 12:46 PM   #7
T-Man
Drives: 09 Cobalt SS Sedan
That's perfectly fine. Anyone who says otherwise is still stuck with the PFI mindset.
T-Man is offline   Reply With Quote
Old 03-27-2018, 08:05 PM   #8
Nabush
Guys,
We need to take in consideration the 91 Chevron I use can use up to 10% of ethanol.
Stochiometric A/F would be then 14.1/1
I switched to Lambda with my Bosh O2 wideband and I'm at 0.88-0.89 at WOT... Which should be 12.5 AFR with E10 (91 Chevron)
Z06 is around 0.85-0.86 with the supercharger...
I read everywhere DI runs leaner but by how much ?.... My 2018 Mustang GT with the new dual injection system runs 11.5 AFR at WOT @6000-7500 rpm and around 12-12.5 before .... which is very rich...
Thanks
Old 03-27-2018, 11:28 PM   #9
KingLT1
KingLT1's Avatar
I spend quite a bit of time reading literature on HPtuners forum. A few members over there have stated that 12.8 is a safe AFR for a naturally aspirated DI gen 5 engine running 93 octane. 12.5 is leaving power or the table, 12.8 is safe, 13.0 is ok, but 13.1-13.2 is getting a bit lean.
Old 03-29-2018, 11:00 PM   #10
Nabush
Yes but AFR doesn't mean anything now since all fuel are E5-E10....
More and More tuners say " work with Lambda" instead...
Should aim for 0.85-0.88 Lambda...
Old 03-29-2018, 11:12 PM   #11
T-Man
Old 03-29-2018, 11:47 PM   #12
Nabush
Originally Posted by T-Man View Post
Speaking of that, I used today C7 Afe Intake tune from Diablosport.
Still not totally relevant as I have LT headers also.
With this tune, Lambda is around 0.89 until 4000, goes up to 0.91 at 4100 then down to 0.87 then 0.85 at 6500. The car runs strong but I don't like this increase of Lambda at 4100...
Tried to add more fuel (+5%) , not a lot of effect... unless the feeling of less torque at low end if I go at 0.85 Lambda instead of 0.89....
When datalogging I see 0.5 to 5 degrees of Knock retard...but completely inconsistent..some runs I have almost nothing, some runs 5 degree mostly between 5000-5500 then it decreases.... Some runs it starts at 3000... Timing is high, between 21 and 26 deg...
Pulls in 3 rd gear show less knock retard than 2nd gear in average...
I read a HP tuner forums and it seems this engine has oversensitive KR sensors...
I tried something this night : copy the stock tune and rename it so intune sees it as a custom tune. then I added 5% of fuel everywhere. I will see tomorrow how it does.
Here are 2 logs 2 minutes apart...
Orange Knock retard
Pink RPM
Purple timing
Light blue : MAF
Blue: Throttle
First one I take 5 deg of knock retard
Second one I take only 0.74 deg of knock retard...
Old 04-01-2018, 11:46 AM   #13
Miami_1LE
Drives: 2018 Camaro SS 1LE
What an idiot. Get out of the car game bro. 12.8 is leaner than 12.5. I'm hoping you made a mistake by writing that, if not and you think the higher the number means the richer the mix your totally wrong.
Miami_1LE is offline   Reply With Quote
Old 04-01-2018, 12:41 PM   #14
6spdhyperblue
Drives: 2SS 1LE
that dude knows more about tuning that you do.
The post prior to edit was saying 13.2.
