Old 03-24-2018, 07:41 PM   #1
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
Help with Elite Engineering installs w/ pics
so I received my product, great people over at Elite Engineering, I didn't receive any instructions, the instructions on there website isn't clear, and what they sent me via email is more geared for centri set up. That said I have attached some pictures with descriptions on what I have questions with. I'm telling you. there is ABSOLUTLY NO ROOM under the hood. Only real space I had was in front of all the pulleys. I have spent close to 2 hours trying all different scenarios as to where to put it.
I feel that where its located is the best spot and made sure that the T stat housing is as tight maybe a few lbs in. tighter than when it came off just as a safety measure. '
Here I have the placement of the bracket they gave me. They actually gave me a few options, but this seems to work the best. yah or nay??
Another view
Another....
Here is where it gets a little confusing.... according to the R&D dude at Elite, I would need to tap into this line or so he states, and this will route to one of the exit lines on the can??
This hose is where it connects currently to the brake booster line.
This is where the (relocated line goes to under the charger PVC) which would be a PITA to get to with out remove the supercharger completely. Assuming that this will connect to the middle of the can or the "enter"??
And here is where the Can is installed but the lines are not ran yet.
Thoughts and help is so much appreciated during this confusing time... Hell, I can install the supercharger with out any issues or hick ups, but this for some reason has my mind blown away...
Ryan
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 03-24-2018, 07:42 PM   #2
oneredry
HYPER SS
oneredry's Avatar
Well one line will end up being drilled into the rubber intake tube so that is that..... not really a fan of it, but what are you going to do.
Ordered: 1/15/2016
Delivered 03/23/16
Old 03-26-2018, 11:14 AM   #3
oneredry
HYPER SS
oneredry's Avatar
anyone? Someone has to have a same set up as I do.
Ordered: 1/15/2016
Delivered 03/23/16
Old 03-26-2018, 12:15 PM   #4
Krypton1le
Drives: 2017 Camaro SS 1LE Krypton Green
I recently installed an lt4 s/c (from ADM) and a mighty mouse catch can - so things are a bit different. But this is where I am pulling vacuum from on the clean side. This runs back to the catch can. Then there is another fitting / hose that runs to the valley cover. I had to remove the blower in order to get access to the valley cover (I have a zl1 valley cover now, which looks a bit different).
Krypton1le is offline   Reply With Quote
Old 03-26-2018, 01:19 PM   #5
oneredry
HYPER SS
oneredry's Avatar
crap. I really don't want to remove the blower if I don't have to.
Ordered: 1/15/2016
Delivered 03/23/16
Old 03-27-2018, 04:51 PM   #6
Krypton1le
Without seeing the setup (Maggie and elite) though, it's really hard to say what's necessary - just wanted to show/tell how I did it with the lt4 blower and mighty mouse setup.
I believe you use the stock valley cover with the pcv valve coming out under the blower - so you'll need to run a line from that to the catch can. Then from the catch can to the clean side (t'd in similar to how I showed)
Old 04-03-2018, 10:04 AM   #7
oneredry
HYPER SS
oneredry's Avatar
UPDATE:
just thought you all should know, I think I was over thinking this. I had a GM TEch friend explain the lay out and after he pointed me in a few directions and with help from all you members/Eliite I think it turned out great!
Ordered: 1/15/2016
Delivered 03/23/16
Old 04-03-2018, 04:32 PM   #8
SC88
Twin Turbo
SC88's Avatar
Drives: 2016 2SS
Originally Posted by oneredry View Post
UPDATE:
Looks good! Did that bracket come with the kit or did you have to order it separately? I ordered mine on Sunday should be here later this week.
Boost, Boost & More Boost
Instagram = BoostedSS
SC88 is offline   Reply With Quote
Old 04-04-2018, 07:44 AM   #9
oneredry
HYPER SS
oneredry's Avatar
They gave me two different types of brackets. when I talked with the R&D dept, they knew what I wanted to how lack of space our compartment is, so they let me choose as to which one I was going to use.
Ordered: 1/15/2016
Delivered 03/23/16
