Old 03-24-2018, 07:21 PM   #1
biker2k
biker2k's Avatar
Drives: 2018 2ss 1le
roto fab dry and car feels slower?
just installed the roto fab dry....
and mishimoto catch can... at the same time
it feels to me like the car is slower less mid range.....
definitely doesn't feel as strong as stock....
now i only have 450 miles on car and am still breaking it in so i cant and haven't really flogged it.... but it doesn't feel the same ....
I did not disconnect battery ..... but i also installed with out disconnecting maf sensor
is this normal... will it learn the cai and get better.... i have onl;y driven it around the neighborhood because of all the crap on the roads and snow melting...
biker2k is offline   Reply With Quote
Old 03-24-2018, 07:35 PM   #2
MAGAUSA
MAGAUSA's Avatar
Drives: 2017 Hyper Blue 1LE
Not my experience. You won't see any difference by changing the air filter - good or bad.
MAGAUSA is offline   Reply With Quote
Old 03-25-2018, 08:19 AM   #3
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
Why would you add a performance mod before finishing the break in? The engine is in its delicate stage of setting the rings and seats but now you risked altering the af ratio. I'm all for performance but I'd recommend leaving it stock for break in as designed.
Joey Soul is offline   Reply With Quote
Old 03-25-2018, 08:20 AM   #4
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
Yeah, I have to agree. On both my 2016 SS A8 and now my 2018 1LE, they both had the RotoFab Dry CAI and an axle back—it felt exactly the same as stock.
2018 Audi TT RS
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
Sold
Old 03-25-2018, 10:22 AM   #5
biker2k
biker2k's Avatar
i understand about break in but I'm not sure how adding a cai would wreck the break in...
I'm still sticking to the parameters... 4k and under till 500 miles and under 80 mph
after 500 i will slowly increase my rpms while still keeping it under 80
at 1500 i will be doing diff fluid and engine oil
any how
i disconnected the battery for 2 hors last night and this morning car does feel better i need a little more time ....
Old 03-25-2018, 11:04 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
No a CAI is not going to effect break-in. Aside from that you are not even running the engine hard enough to realize the Rotofab benefits being most of the gains are above 4k RPM.
Old 03-25-2018, 11:05 AM   #7
Deputy Dog
Drives: 2017 Super Sport Cam.
It might take a day or two for the computer to adjust. When I had my 11 Camaro I changed my exhaust. That day driving it just seemed to have less response. The next day it was like a different car.
Deputy Dog is offline   Reply With Quote
Old 03-25-2018, 11:15 AM   #8
enzia35
Drives: '16 Garnet Red 1SS
Just a cai will not do much. Especially from the butt dyno.
'16 Camaro 1SS
'18 Miata GT
Old 03-25-2018, 06:28 PM   #9
F1FTY
Drives: 2018 ZL1
Need the ported TB/IM to feel a CAI difference, imo.
F1FTY is offline   Reply With Quote
Old 03-26-2018, 09:47 AM   #10
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
i only say it can cause the engine to run a bit leaner then designed due to the higher air flow. Nothing detrimental.
Old 03-26-2018, 09:50 AM   #11
Yellow6thGen
18 ZL1 A10 Convertible
Drives: White ZL1 Convertible
My dyno run says different and my car is faster. After the headers & green Hf cats were installed I gained 45Hp and 33Tq to the wheels I can tell the difference but only gained minimumly with only CAI
Yellow6thGen is offline   Reply With Quote
Old 03-27-2018, 03:13 AM   #12
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
Anyone on here that can tell the difference between stock and a stock + intake has a REALLY SENSITIVE butt dyno.
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 03-27-2018, 06:05 AM   #13
Red Hot 2017 SS
Red Hot 2017 SS's Avatar
Drives: Red Hot 2017 Camaro SS A8
I noticed a slight difference in mine and the sound but I broke my car in the way I’m going to drive it
Red Hot 2017 SS is offline   Reply With Quote
Old 03-27-2018, 09:15 AM   #14
TunaMelt
Drives: 2017 Camaro SS 1LE
If you're truly feeling a significant difference then I'd make sure you don't have any air leaks downstream of the airflow sensor. This could be throwing off your air/fuel ratio. I'd also consider if the sound change is messing with your head. Does it still have the sound tube intact?
TunaMelt is offline   Reply With Quote
