Old 03-24-2018, 03:10 PM   #1
Tulsa_SS
2017 1SS 1LE
Tulsa_SS's Avatar
Drives: 2017 1LE
DSCMagnetic Ride System Controller!
A friend of mine who has a Z06 vette started telling about these controllers for the Magnetic ride on his car. He took me for a test drive and I could not believe how much better the ride was in all modes and how controlled the car felt. So I broke down and got a Controller for my 2017 SS 1LE when I got my tax return. Easy install in the trunk of the car. Install after 1 year of driving car completely stock.
The Difference!
Wow! the way my car rides and performs now after putting this device in is remarkable. Dailey ride in Sport mode and Touring on the highway has improved enough to make it feel like a different car. It gets the power to the road. My car used to always engage the traction control light when giving it the gas in 1-3 gears(any mode). I have only seen that light come on once since installing the controller. The car feels faster because it is getting the power down. Rolling around corners hard the car doesn't lean the same, it feels like it is in complete control. When breaking hard the cars nose barely dives compared to what is used to. Launching with a Standard is challenging but feels like you have better launches. Best 0-60 went from 4.4 to 4.2 (on street)and I think I can get lower. I have not been out to our racetrack here Oklahoma called Hallet since the change but will report back after my first run this year.
If you have any gen6 car with Magnetic ride this device will make your car ride so much better. Even if you never go to the track it will make the car more enjoyable too drive.
Check DSCsport out at http://www.dscsport.com/camaro/
Tulsa SS
2017 1LE
Tulsa_SS is offline   Reply With Quote
Old 03-24-2018, 03:19 PM   #2
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
I used to be interested in this controller but it seemed everyone was having connectivity problems related to their harness pigtail. Spendy toy to be hit/miss. Glad to see this device pop up for discussion again.
ninetres is offline   Reply With Quote
Old 03-24-2018, 03:22 PM   #3
Tulsa_SS
2017 1SS 1LE
Tulsa_SS's Avatar
Drives: 2017 1LE
I had no problem getting it attached. I had read some people have had issues and was ready for it, but it was smooth going on.
Tulsa SS
2017 1LE
Old 03-24-2018, 06:56 PM   #4
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
So what is the install like? What has to be done?
Did you have to interface to a Software suite on your PC to set something up, or is this module pre-set and a simple "connect & go" ?
Old 03-25-2018, 12:08 AM   #5
Tulsa_SS
2017 1SS 1LE
Tulsa_SS's Avatar
Drives: 2017 1LE
Just unsnapped controller, sprayed some wd-40 like DSC recommended and popped in in. One drawback I did mention is it is a little thick at the top than the original oem. I just used some duck tape too hold it in.
Here is some pics from DSC
http://www.dscsport.com/downloads/in...stallation.pdf
The latest controller has wifi built in so using a laptop or phone to attach to controller like a Wireless Access Point and use a web browser to see. To use PC software you have to connect to controller via USB cable.
The controller came with a Gen 6 Camaro setting loaded.
Tulsa SS
2017 1LE
Old 03-25-2018, 09:56 AM   #6
Eldi Z
Nice and easy.
Interesting that you feel such a great difference compared to the stock system.
I would have guessed that GM did a special effort in perfecting the settings for the 1LE in particular.
Can you further describe where you feel the differences? Add to your above review?
All-in-all, if this unit indeed proves itself for many users in the field, then I expect this to be a very popular mod. It is pricey indeed though and it would be interesting to also get a feel of the Price-to-Performance ratio.
Old 03-25-2018, 12:39 PM   #7
Chub2000
Chub2000's Avatar
Drives: 2018 camaro zl1 , 2007 porsche GT3,
My car was the test mule for DSC
Chub2000 is offline   Reply With Quote
Old 03-25-2018, 12:45 PM   #8
WhyUMad1LE
Drives: 17 SS 1LE
Is there any difference in tour/sport/track settings with this controller?
Old 03-25-2018, 04:25 PM   #9
Tulsa_SS
2017 1SS 1LE
Tulsa_SS's Avatar
Drives: 2017 1LE
Like with the stock only better. Touring is definitely makes the car ride nicer. Sport and track are stiffer but it still rides a lot better in those modes than stock. Have not tried in snow/ice mode.
You can manually go in and adjust the setting on the controller but I am content with the stock settings right now. I am sure in time I will want to manually dial it in a little but I like it where it is for OOB settings right now.
My Vette friend pointed out if you sell the car you can easily take this out and sell the DSC controller.
Tulsa SS
2017 1LE
Old 03-25-2018, 05:55 PM   #10
Chub2000
Chub2000's Avatar
I'll sell mine since I traded the car for a zl1 1le.. $600 takes it.
Old 03-25-2018, 06:09 PM   #11
F1FTY
Drives: 2018 ZL1
PMed
F1FTY is offline   Reply With Quote
Old 03-25-2018, 07:15 PM   #12
Tulsa_SS
2017 1SS 1LE
Tulsa_SS's Avatar
Drives: 2017 1LE
Won't that controller work on your new car too?
Tulsa SS
2017 1LE
Old 03-25-2018, 09:10 PM   #13
Chub2000
Chub2000's Avatar
Originally Posted by F1FTY View Post
PMed
Sold .thanks Dave
Old 03-25-2018, 10:18 PM   #14
tx6g1le
tx6g1le's Avatar
Drives: 2017 Camaro 1LE
Sold .thanks Dave
Well, that is disappointing.
2017 Hyper Blue 1LE
tx6g1le is offline   Reply With Quote
