![]() Drives: Fireball 700 Join Date: May 2017
Mass Airflow Sensor on Procharger?
Where is the mass airflow sensor located with a procharger?
I have a engine code related to MAS not functioning correctly and it seems that it has been relocated to install the procharger system. It's usually located in between the throttle body and factory intake. Could it of have been relocated closer to the procharger radiator? Is this a job where I have to remove my bumper for a MAS replacement? in advance
![]() Drives: 16’ 2SS A8 HBM Procharged Join Date: Jun 2017
It’s on the bottom of the tube before it goes into the throttle body. Check the “extension” harness that makes the factory plug longer. Seen it a few times. Make sure none of the pins are bent and that it’s plugged in all the way.
16' 2SS A8 Hyperblue | P1SC-1, Race IC | JMS fuel pump voltage booster | Jannetty custom tune | Elite E2-X catch can | M017 Wheels
