Old 03-22-2018, 06:21 PM   #1
brzfan
Drives: '18 Camero V6 1LE
18" wheels for track (V6 1LE)
Planning to run square 18x9.5" wheels for more tire selection and cheaper consumable costs. If I go with a 40 aspect ratio, that should be pretty close to the diameter of stock size. I will probably run around -2 to -3 front camber, and -2 to -2.5 rear camber. I want to leave upgrade path to SS/ZL1 brakes or BBK open if it is needed in future. Anyone running a similar setup? I have seen a lot of posts about smallers wheels not clearing, but that seems to be more about the SS 1LE.
brzfan is offline   Reply With Quote
Old 03-22-2018, 06:29 PM   #2
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
Originally Posted by brzfan View Post
Planning to run square 18x9.5" wheels for more tire selection and cheaper consumable costs. If I go with a 40 aspect ratio, that should be pretty close to the diameter of stock size. I will probably run around -2 to -3 front camber, and -2 to -2.5 rear camber. I might upgrade to SS/ZL1 brakes or BBK later on if it is needed. Anyone running a similar setup? I have seen a lot of posts about smallers wheels not clearing, but that seems to be more about the SS 1LE.
No need to target factory OD. Running smaller OD will only tighten gear ratios, no adverse effect aside from speedo reading high. I run 18’s that are 7-8% smaller OD than stock. I love the gearing change. PTM, ABS, etc work perfectly with smaller OD.
Oh, and OD= overall diameter of tire
Provoste is offline   Reply With Quote
Old 03-22-2018, 07:17 PM   #3
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
currently run 18x9 Apex PS-7 wheels with et 31 spacing, and the 4 piston brembos. will be upgrading to the 6 pistons within the month.
my next set of wheels from apex will be 9.5 inches wide in an 18 as well. plan to run the 265/40-18 re71-r's
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
