Old 03-21-2018, 08:56 PM   #1
laynlo15
Drives: 2022 Lt1 A10
703 rwhp pull
Old 03-21-2018, 09:05 PM   #2
Drsagacity
Drsagacity's Avatar
Nice!
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 03-21-2018, 10:15 PM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Nice...that blower is singing!
Old 03-21-2018, 10:20 PM   #4
laynlo15
Wait till I put the 70 mm pulley on, its gonna be like Pink Floyd dark side of the moon. Shit that may not be it but love the band and the song and the whine of the SC.
Old 03-22-2018, 03:57 AM   #5
boostednut
Drives: Nothing cool atm
Whoa dark side of the moon? don't get ahead of yourself there
I remember reading about your build. Looks like it's running strong! Still stock shortblock! Any other changes? Also what's the setup for the meth nozzles? One, dual? Sizes?
Killer setup.
boostednut is offline   Reply With Quote
Old 03-22-2018, 04:47 AM   #6
laynlo15
Its all in my sig, but 75mm pulley, Lt4 injectors, Lingenfelter Big Bore High Pressure Pump, Vp Ms109, M1 Methanol 50/50 water mix and yes total stock internals.
Old 03-22-2018, 06:44 AM   #7
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Fun stuff...
driven2exceSS is offline   Reply With Quote
Old 03-22-2018, 07:18 AM   #8
DFW1LE
DFW1LE's Avatar
I see 9s soon
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ
Old 03-22-2018, 08:04 AM   #9
ShizzySupra
Drives: 16' Camaro 2SS
What boost level? Since it was a 5th gear pull you are actually making around 730whp
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R
9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp)
ShizzySupra is offline   Reply With Quote
Old 03-22-2018, 10:40 AM   #10
steelheadrob
Tactical Garage
steelheadrob's Avatar
Over 700 rwhp is impressive on stock internals. How much more are you planning on pushing the stock internals before you go forged? Others have suggested that 700 is about the max the stock internals can hold up to before you start to see problems.
steelheadrob is offline   Reply With Quote
Old 03-22-2018, 11:39 AM   #11
Drsagacity
Drsagacity's Avatar
Isn’t 5th fear the 1:1 gear ratio? Seems like any other gear would cause incorrect readings.
TBD performance
Old 03-22-2018, 11:58 AM   #12
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
This shows 6th as 1:1
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
Old 03-22-2018, 12:04 PM   #13
aka Reckless
aka Reckless's Avatar
Drives: 2016 2SS Camaro
6th gear is 1:1 on the A8, but too much mph for dyno. Most will pull in 5th. Nice results!
Might be more like "Wish You Were Here" results though
aka Reckless is offline   Reply With Quote
Old 03-22-2018, 03:44 PM   #14
Drsagacity
Drsagacity's Avatar
Are you saying that dyno doesn't account for the gearing when it's not 1:1 ratio? On a stock car, rwhp reflects 390rwhp, rated at 455hp at the flywheel. That' is approximately a15% loss. If we apply that same calculation to Laynlo's car, he's running about 827hp at the crank. . .that's pretty sick.
I will have to spend some time looking at the math, but in theory, we should be able to take the RWHP in any gear and apply a factor to account for the gearing for the run and figure out real RWHP.
TBD performance
