Old 03-20-2018, 11:47 AM   #1
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
ZL1 in-tank fuel pump number?
Trying to find an in-tank ZL1 fuel pump, but the old 23377988 part number must be superseded. Looking at the different parts website, I see 4 different pumps listed.
Anyone know what the current correct part number is?
Atomic Ed is offline   Reply With Quote
Old 03-20-2018, 12:40 PM   #2
steelheadrob
Tactical Garage
steelheadrob's Avatar
I think it is 23377989.
steelheadrob is offline   Reply With Quote
Old 03-20-2018, 12:44 PM   #3
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
That's the cts-v LT4 part#, also the LT1 camaro with 1LE package.
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 03-20-2018, 02:33 PM   #4
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Low pressure ZL1 intank pump - 23377989. Steelheadrob is correct.
Dysan911 is offline   Reply With Quote
Old 03-21-2018, 06:45 PM   #5
Atomic Ed
Finally found the AC Delco cross reference part #: M100183
Edit: looks like AC Delco's new part # is M100263. Either one will work.
Old 03-26-2018, 07:26 PM   #6
SLO-GOAT219
Drives: 2004 GTO
Wait so the 1le comes with the same intank pump that the lt4 motor cars do?
SLO-GOAT219 is offline   Reply With Quote
Old 03-27-2018, 01:44 AM   #7
boostednut
Drives: Nothing cool atm
yes
boostednut is offline   Reply With Quote
Old 03-27-2018, 06:56 AM   #8
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
Just a heads up. I heard some are using this instead of the LT4 LPFP.
https://dsxtuning.com/collections/au...nt=31838322187
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
Old 03-27-2018, 08:24 AM   #9
parbreak
Drives: 2017 50th Camaro SS
That's the one I'm considering
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 03-27-2018, 09:57 AM   #10
steelheadrob
Tactical Garage
At what HP would something like this be needed? LT4 LPFP is $175 vs $1000, if you need more you can add a boost a pump for another $400 and still be less than $600 total.
Old 03-27-2018, 10:10 AM   #11
Atomic Ed
Same question here. Seems that if you're below 700 rwhp, the ZL1/1lE pump and/or a boost a pump will do the trick.
Rob, are you coming to the Tri-Cities for a tune soon? I'm scheduled for April 16th.
Old 03-27-2018, 10:21 AM   #12
JFM-jr
JFM-jr's Avatar
Parish has done some testing with various voltages on the ZL1 intank pump. With a JMS voltage booster putting about 17.5 volts to this pump I think most guys power goals would be covered.
http://www.camaro6.com/forums/showpo...0&postcount=15
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 03-27-2018, 10:25 AM   #13
steelheadrob
Tactical Garage
I talked to Kiazen last week. They are booked about a month out. Current plan is to install the Whipple this weekend, run the canned for a while until I can get something scheduled then add the LT4 fueling components before I get the tune done.
Are you planning on adding all of the LT4 fueling components and the plate you were talking about?
Old 03-27-2018, 11:07 AM   #14
Atomic Ed
At this point, only the ZL1 pump. Kaizen thinks they can comfortably get me to 600ish rwhp without the LT4 HPFP or injectors. They just did a C7 that pulled 609 rwhp on a bone stock LT1 fuel system. They seem to have a good handle on all the tuning fuel tricks.
This tune will be with the thermal isolation plates on, some port matching and intake flow cleanup, IAT sensor relocation, Rotofab CAI, and a drop in pulley size. Should be interesting to see if my ideas come together and add anything.
