Old 03-19-2018, 12:32 PM   #1
1Lars1
Drives: 2018 Chevrolet camaro V6RS
Break in period for new 2018 Camaro?
Hey guys,
just got the new 2018 Camaro V6RS (great great great car). owner manual says first 500 miles are the break in period. can anybody recommend how to handle the vehicle when bought and for how long? tried searching for it through out the forums - no luck. thanks!
2018 Chevy Camaro V6RS
1Lars1 is offline   Reply With Quote
Old 03-19-2018, 01:17 PM   #2
DirectTo
DirectTo's Avatar
Drives: Sold!
This is the track preparation guide but page one gives you good info:
https://my.chevrolet.com/content/dam...tion-guide.pdf
DirectTo is offline   Reply With Quote
Old 03-19-2018, 07:01 PM   #3
1Lars1
thanks, I have that.. just wanted know if any one has any other suggestions.
and also, how critical is it to break in the vehicle - out of curiosity?
Old 03-19-2018, 08:16 PM   #4
enzia35
Drives: '16 Garnet Red 1SS
Some do the break in, some don't. I did to mine, plus oil changes at 500 and 1500 miles.
'16 Camaro 1SS
'18 Miata GT
Old 03-24-2018, 07:54 AM   #5
IanCC
IanCC's Avatar
Drives: Summit White V6 M6 NPP
This is so amazing! I had no idea this document existed. I wonder how much carry over to my V6 M6 (non-1LE) it has for track day advice?
IanCC is offline   Reply With Quote
Old 03-24-2018, 08:00 AM   #6
IanCC
IanCC's Avatar
Originally Posted by 1Lars1 View Post
Hey guys,
I followed the break-in period for the first 2000 km (1200 mi) and it took all of my will power to keep it below 4000 RPM. I changed my oil at 200 km (120 mi) and again at 2000 km (1200 mi) with fully synthetics. Absolutely no idea if it was necessary or needed, but being my first brand new car and first Camaro, I thought it was worth doing for my own peace of mind.
Old 03-24-2018, 11:41 AM   #7
Nsxmatt
Drives: 2017 Camaro
From what I read in the manual, the break in period is 1500 miles. But its all subjective. I do know most companies ship cars with oil additives to help break in so changing it too soon could do more harm than good. These engines aren't like the old days where there is a ton of excess manufacturing junk floating around you need to flush out.
Nsxmatt is offline   Reply With Quote
Old 03-24-2018, 10:00 PM   #8
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
I remember reading a thread on recommended break in by one of the forum sponsors on C5, and one of the big things highlighted for engine break in was if you do turn high rpm at all that you should then also engine brake up to your stop to draw oil back up the cylinders walls.
(While I was typing this, I found at least one of the threads I was thinking of) http://www.camaro5.com/forums/showth...ighlight=break
My '13 LFX has 97k on it and does not use any oil. I'm at 47% oil life right now and the line on the dipstick has only barely moved. Break in is definitely subjective, but you always want to do it with conventional high zinc oil. I am a believer of a harder break in though, especially since both of my college friends that also have LFX's use oil constantly (more than 1 quart between changes).
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
DSX_Camaro is offline   Reply With Quote
