Programming a replacement instrument cluster
I have purchased off of Ebay an SS instrument cluster for my 2016 V6. Does anyone know how I can reprogram the odometer reading to match mine? The replacement shows about 8000 miles. Mine is at 22000 miles.
![]() ![]() Drives: 18 zl1 Join Date: Aug 2017
I know the dealership has the ability to reprogram gauge clusters, but correct me if I'm wrong, I believe they need a code from gm to be able to do so, at least that's how it is for some dealerships.
I know they can do this to replace a malfunctioning odo, but I'm not sure if they will do it just because you have another one and want to put it in. |
#3 | |
I think it will be technically possible, but suspect the dealer is going to want a few hundred for the "reprogramming." |
#4 | |
![]() Drives: Summit White V6 M6 NPP Join Date: Feb 2017
http://www.camaro6.com/forums/showthread.php?t=512231 I'm going to do this myself for my 1LT. I just spent the day on the phone with my GM dealer and parts shops and I think you'll find the dealer's won't reprogram them for you. They often don't know how and are likely told by GM not too. I think it may be part of the upsell for the 2LT enhanced package so you buy that at the time for the extra $$$ and don't just upgrade the display later, like most of us LT/RS owners want. The thread above quotes a company called White Audio and Media that will do it for you if you mail the cluster to them. They reprogram it and mail it back. |
![]() Drives: 18 zl1 A10 Join Date: Aug 2020
Does anyone know if you can put a zl1 cluster in an SS both are 2018
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
The ZL1 cluster has a boost gauge where the battery/amp gauge would be. Don’t know if it would be worth the cost to swap out since you wouldn’t need a boost gauge in your SS unless you have a supercharger. The cluster is basically the same as the SS.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
<Insert Cars You Own Here>
#8 | |
Long hauler
https://www.whiteautoandmedia.com/pr...c-programming/ If you have the 7” screen then you lose the volume and favorites paddle underneath the wheel, if you have the 8” then you need this Gen5DIY harness to get some features https://www.gen5diy.com/products/16-...pgrade-harness
2016 1LT v6 - Totaled Happiness: Infinite |
