Old 03-15-2018, 05:33 PM   #1
Badmojo
aka BeastZL1
Badmojo's Avatar
LT4 Boost Bypass Valve Adjustment
Some forum members have stated benefits from adjusting the boost bypass valve. I found a Youtube video showing the location and how to adjust the valve to ensure that the bypass doesn’t prematurely open and lose boost for an LSA. I can’t locate information on the LT4.
The following information would be helpful:
1. Post a picture of the bypass and the location in the engine compartment.
2. Explain the “adjustment” procedure.
@Lt1z350 You seem to be a proponent of this, but your post aren’t descriptive enough in other threads. More info would be greatly appreciated.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 03-16-2018, 11:04 AM   #2
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
So cooling mods, adjust the bypass valve and some other unknown trick and you're running .2+ seconds faster on average than every other "fast" stock A10 pass? I'm probably game to try it, but I don't see how a bypass valve adjustment is taking you from 7 PSI (Stupid low for a stock LT4) to 10-11+, in fact that's not possible IMO without a pulley. What gives? Also, I thought the stock tune wouldn't even really allow the car to make any more power, hence why adding intakes/throttle bodies and the like on stock tune don't, in your opinion, gain anything because the tune just limits the timing and whatnot to keep it at stock power?
Old 03-16-2018, 11:10 AM   #3
rjacobs
Drives: none
I just went and checked mine. It was blue lock tite'd in place. I backed it out and it basically immediately lost contact with the little arm for the canister. I screwed it back in until it JUST touched. I MAY have it 1/8-1/4 turn further out than it came from the factory.
rjacobs is offline   Reply With Quote
Old 03-16-2018, 11:17 AM   #4
Can'tHave2MuchHP
Drives: Fast
Notice any changes? Did you check boost before so you know what it goes to after?
Old 03-16-2018, 11:22 AM   #5
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
Pics of the Parts being discussed would be helpful.
ninetres is offline   Reply With Quote
Old 03-16-2018, 11:32 AM   #6
djfury05
djfury05's Avatar
Drives: 2017 ZL1 A10
This is what you're looking for. It is the solenoid and metal rod assembly. To the right of the pic under the coolant cross over is an allen head screw with blue loctite. This is what you'll adjust.
djfury05 is offline   Reply With Quote
Old 03-16-2018, 11:36 AM   #7
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Reference Picture to put you in the area.
screw and GAP
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 03-16-2018, 11:41 AM   #8
Buzzmanb12
Drives: '17 ZL1
One more shot
Here's another pic.
Front of motor, right behind TB.
LOL, Almost life sized too.
Buzzmanb12 is offline   Reply With Quote
Old 03-16-2018, 11:53 AM   #9
rjacobs
Drives: none
I havent gone and driven it yet.
im not expecting anything though as I believe mine was probably set correctly from the factory if its supposed to have 1/16" pre-load, I would guess mine did.
Old 03-16-2018, 04:58 PM   #10
2017-ZL1
2017-ZL1's Avatar
Drives: 2017 Red Hot ZL1
Wouldn't expect a lot unless it's gross off. The bypass blade should be slightly "off seat", to avoid grooving and a possible binding. Probably around 1/8th of a turn off seat will handle the job.
2017-ZL1 is offline   Reply With Quote
Old 03-17-2018, 07:28 AM   #11
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
I made this same adjustment on my Gen5 ZL1 and I felt the difference. Going to try it.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 03-17-2018, 08:52 AM   #12
Tampabucs4
Tampabucs4's Avatar
Drives: 2018 blue ZL1
I am still not sure what I am looking at when I adjust sink don’t do something wrong. Can someone break it down detailed if they have done it. Also if it’s so popular why is there no videos for an lt4 on YouTube
Tampabucs4 is offline   Reply With Quote
Old 03-17-2018, 09:34 AM   #13
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
There are videos on youtube for the LSA, same concept.
-Bobby
Old 03-17-2018, 10:13 AM   #14
Badmojo
aka BeastZL1
Badmojo's Avatar
Thank you to everyone that responded with tech info.
2019 Camaro ZL1 1LE
adjustment, boost, bypass, lt1z350
