Old 03-15-2018, 03:36 PM   #1
Osbornsm
Drives: 2018 SS 1LE
Smile Do any 19's clear SS 1LE brakes?
New forum member and SS 1le owner.
Is there a 19 inch wheel that will clear the SS 1le big brakes?
The rotors are 14.6 diameter, I had 14" rotors with 18" wheels before, need to check.
More tire choices and less expensive rubber for 19's.
Thanks all,
- Sean
Osbornsm is offline   Reply With Quote
Old 03-15-2018, 03:52 PM   #2
1LExtreme
Drives: 2018 Camaro 1LE
Yes there is a lot of 19 inch wheels that will fit. If you do a little search on the forum I believe some people even fit 18s.
I was told by APEX that they would release a new wheel just for Camaro in the Spring. So if you can wait a little you will have a chance to get 19 inch wheels with perfect fitment and no need for spacers.
1LExtreme is offline   Reply With Quote
Old 03-15-2018, 04:02 PM   #3
Osbornsm
Drives: 2018 SS 1LE
Omg so much yes.
Have any detail on the "new" wheels coming out?
Old 03-15-2018, 04:06 PM   #4
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
Thanks all,
- Sean
18’s fit just fine. See my avatar
Provoste is offline   Reply With Quote
Old 03-15-2018, 10:16 PM   #5
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
The Cadillac ATS-V uses identical brakes and only comes in 18" wheels.
Old 03-16-2018, 09:38 AM   #6
TinkerbellZL11LE
Drives: 2018 ZL1 1LE
You could put factoryZL1 1LE 19 inch rims on they clear my factory 15.4 inch rotors on ZL1 1LE forged wheel not cast!
TinkerbellZL11LE is offline   Reply With Quote
Old 03-16-2018, 01:33 PM   #7
booyaa56
booyaa56's Avatar
Drives: 2017 Camaro 1LE
Yes
booyaa56 is offline   Reply With Quote
Old 03-16-2018, 01:45 PM   #8
Ecchi667
Ecchi667's Avatar
Drives: 2016 Camaro 2SS, 6spd M
You can also run factory 5th gen z28 wheels. They're pretty groovy.
Ecchi667 is offline   Reply With Quote
Old 03-16-2018, 01:51 PM   #9
jaymsu
Yeti's Daddy
jaymsu's Avatar
Drives: ATS-V, Prowler, M6 V10
My track wheels are 19 inch (Apex PS-7 19*10 et 25), and my winter wheels are 18 inch. Just make sure you get right offset so it doesn't interfere with shocks. (My car is not 1LE but has 6 piston)
2SS Nightfall Grey /Adrenaline red interior
NPP / MRC / Nav / 6 Spd
1100: 7/27/15 <SSWNNN>
3000: 9/04/15 <TPW:10/19/15>
3800: 10/19/15 <VIN: 117740>
6000: 12/16/15
jaymsu is offline   Reply With Quote
Old 03-16-2018, 08:25 PM   #10
Osbornsm
Drives: 2018 SS 1LE
Just want to be sure that you all are running WITHOUT spacers. I won't track on those.
Old 03-16-2018, 08:46 PM   #11
HyperspaceTurd
HyperspaceTurd's Avatar
Drives: 17 1SS 6MT, 09 Tacoma TRD Sport
+1 internets for spelling brake correctly in this context.
It's the little things...
HyperspaceTurd is offline   Reply With Quote
Old 03-17-2018, 01:35 AM   #12
JeromeS13
Drives: 2017 1SS/1LE
I'm running a set of 19s with no spacers. Lots of people are.
Old 03-17-2018, 05:32 AM   #13
1LE caSSper
1LE caSSper's Avatar
Drives: White 1LE
I run tsw interlagos year rounddaily driving & track duty , very durable very cheap very light
1LE caSSper is offline   Reply With Quote
Old 03-17-2018, 10:30 AM   #14
Osbornsm
Drives: 2018 SS 1LE
Okay so the answer is "yes".
Now, is there a 19 which matches OEM widths?
Pardon, I'm searching but haven't found yet.
