Old 03-15-2018, 01:50 PM   #1
Taylor0262
Drives: 2017 Camaro SS
305/45/17 which rim?
I just got a set of 305/45/17 drag radials . Now i need to find a good deal on a set of rims that will fit my 2017 camaro ss good with no rubbing. Its a stock height car. I know everyone pretty much runs drag stars but is there a cheaper option available? Also what backspace would you recommend? Thanks in advance.
Taylor0262 is offline   Reply With Quote
Old 03-15-2018, 06:20 PM   #2
Cdflyer
Cdflyer's Avatar
Drives: 2016 1SS 6speed
The RTS Series aren’t cheaper, but I like them. They’re light and fit without issue. 17x10’s. Call Carlyle Racing. They’ve usually got the best deal on them.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials.
Cdflyer is offline   Reply With Quote
Old 03-15-2018, 06:42 PM   #3
Taylor0262
Ok thank you. I will certainly look into it. Gives me atleast some more options
Old 03-15-2018, 11:26 PM   #4
KonigWolf
Drives: 2016 2SS A8
Here is what I am using. 17x9.5" +38 offset. Rubs a little bit on the driver side fender liner, but not bad.
https://www.amazon.com/dp/B004J34PNW...v_ov_lig_dp_it
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA
KonigWolf is offline   Reply With Quote
Old 03-16-2018, 03:56 PM   #5
Taylor0262
Ok cool! Do you think i could trim in inner fender to avoid the rubbing?
Old 03-16-2018, 07:20 PM   #6
KonigWolf
Drives: 2016 2SS A8
I've put 600 highway miles, 5 drag strip passes, about 20 Mexico digs, and doing burns outs to clean the tires, an I haven't worn a hole in my fender liner yet. I've moved the wiring harness on the driver side as a precaution but other than that, I'm just going to let it rub a hole, then look into maybe patching it. On my drive side M/T I can see where it's kind of rubbed on the very edge of the tire; I think it only does it on launches though, other wise I'd already worn a hole.
