Old 03-12-2018, 09:00 PM   #1
m4nat
m4nat's Avatar
Question Reluctant car start - Anyone else?
I tried searching for a thread like this one to no avail.
But does anyone else’s SS shave a reluctant start up? Almost like the car is about to give out before starting.
I thought it was the battery and checked the voltage; it wasn’t.
I thought it was spark plugs....but spark plugs? On a car with 30k miles? No way
Do you guys think it could be our cam? Since the LT1 does have an aggressive cam.
Let me know what you guys think, would appreciate it. Also it’s not every single time, it varies.
IG: @manat.0
m4nat is offline   Reply With Quote
Old 03-12-2018, 09:27 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
This was written up a year ago or so , I can't remember exactly, you might search, for crankshaft position sensor
Old 03-12-2018, 10:03 PM   #3
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
Heat soaked starter, Bad battery, loose ground, or crank sensor. Common issue for the 16. Let me guess, only happens after restarting the engine while its hot (restarting within 15 minutes after engine shutdown).
soloknight6 is offline   Reply With Quote
Old 03-12-2018, 11:35 PM   #4
internationlriders
internationlriders's Avatar
Drives: 2017 SS 1LE
Crank sensor caused this on mine, it move or something the dealer said.
internationlriders is offline   Reply With Quote
Old 03-13-2018, 03:26 AM   #5
Wierd Harold
Drives: 2017 2lt rs
There was a thread awhile back about crankshaft thrust bearing.
Wierd Harold is offline   Reply With Quote
Old 10-05-2018, 11:53 PM   #6
moesSS
Drives: 2016 Camaro SS
Has anyone changed their crankshaft position sensor on their own? My car has been giving me this problem for the past year but I don’t wanna pay the dealership $600+ just to change a sensor.
moesSS is offline   Reply With Quote
Old 10-06-2018, 12:51 AM   #7
whitelightning011
whitelightning011's Avatar
Drives: '16 1SS A8 w/ NPP
Is a heat soaked starter something that needs service attention or is it normal?
Sometimes I start my car and it cranks really slowly before speeding up the cranks and starting the motor. Sort of like chug... chug......chug..chug..chugchugchug *start*.
whitelightning011 is offline   Reply With Quote
