Old 03-12-2018, 12:59 PM   #1
6th_gen_gino
Drives: 2016 camaro 2.0t gray
Universal Front mount intercooler installed
Finally got the job done, end cost was 550 bucks. Some bumper trimming had to be done but could be avoided if you pick a different intercooler size. The stock intercooler was left in place and the universal piping snaked around it.
6th_gen_gino is offline   Reply With Quote
Old 03-12-2018, 01:01 PM   #2
6th_gen_gino
Big thanks to jacfab for sending out the MAP sensor block
Old 03-12-2018, 01:03 PM   #3
6th_gen_gino
https://youtu.be/iMdbn_jZj3E
Old 03-12-2018, 04:10 PM   #4
Beast-Y-Blue
Drives: Hyper Blue 2016 Camaro turbo
Looks good but one queation. Why was sto k intercooler left? Doesnt it have any significant weight savings by removing it?
Beast-Y-Blue is offline   Reply With Quote
Old 03-12-2018, 04:19 PM   #5
6th_gen_gino
I'm sure there would be some weight savings but it's a pain to remove
Old 03-12-2018, 04:36 PM   #6
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
How much cheaper do you think this could be done? Or is that pretty much as cheap as you could put it together? I want to do an intercooler too, but I'm not sure if 200$ is worth the extra fab work and time piecing everything together VS just buying the prefab kit from ZZP..What's your thoughts now that your done?
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 03-12-2018, 06:11 PM   #7
6th_gen_gino
First I would get am intercooler with slightly different dimensions, and honestly if you don't mind using a few more couplers the. U wouldn't need a fabricator
Old 03-12-2018, 08:06 PM   #8
Beast-Y-Blue
Soooo.... if you had to do it again what size would you use, cause ive seen a member use one bigger than yours.??
What size would u recommend base on ur experience? What xtra parts are needed?
Also ZZP is $250 more + shipping i suppose but that still does not include installation.... if i read right it cost u a total of $550 including install shipping ..etc.. ?? Right?
Old 03-12-2018, 08:31 PM   #9
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
Looking forward to some numbers now.
Old 03-13-2018, 10:54 AM   #10
6th_gen_gino
I'd love to know the dimensions of that other person's intercooler. if you mount directly under the crash bar you could get away with a slightly wider and thicker IC, it would just have to be shorter. As far as parts I used 5 couplers, I could have used 4 just on the end attachments but that would require removing the old IC to make room on the hot side. Just be very careful with the AC lines they are weak as heck.
Old 03-13-2018, 05:38 PM   #11
15CamaroV6
Drives: 2016 Chevy Camaro I4 Turbo
Gino my man. good job. looks good in there. notice any difference anywhere?
15CamaroV6 is offline   Reply With Quote
Old 03-13-2018, 08:21 PM   #12
6th_gen_gino
To be cometely honest I haven't really ragged on the car since it's gotten back, I wanna have my tuner check that everything is perfect
Old 03-15-2018, 02:14 PM   #13
whiskeyfed
Pat
whiskeyfed's Avatar
Drives: 2017 Camaro 1LT I4 Turbo A8
Smart man ^ I am currently looking into Michimoto's universal options. Trying to ask around to see what the biggest IC we can get that will fit. The ZL1 replica bumper will allow for a much bigger IC from a guy I talked to on IG but that is totally not for me.
Ill try and remember to update with any further info.
Gino, hell of a job
Follow me on Instagram @whiskeyfed
Subscribe on YouTube Whiskeyfed Camaro
Follow my Build Thread The WhiskeyFed Camaro
Current Modifications: JacFab Boost-O-Lator, Injen Evolution CAI, ZZP Catless Downpipe, RPM 3" Charge Pipe, Mishimoto Oil Filtration/Coolant Systems, R1 Concepts Brakes Package, Eibach Pro-Kit Lowering Springs, PTP Lava Exhaust Wrap & Turbo Blanket
DYNO SHEET: 297whp / 374wtq
Tuned by #danytechtuning
whiskeyfed is offline   Reply With Quote
Old 03-15-2018, 03:08 PM   #14
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
No problem!
Gino, hell of a job
I'm going to be finally starting on the intercooler tube and bracket kit, the intercooler I have here is a mishimoto G line.
