Old 03-12-2018, 08:05 AM   #1
Hughes
Drives: 2017 Camaro 2SS Hyper Blue A8
KB Boost a pump on 6th gen
I’ve been reading and reading but haven’t found any solid information. I have an ECS supercharged SS upgrading to lt4 injectors/hpfp and ZL1 in tank fuel pump. Plan to run car on e85 and was thinking adding a boost a pump for some added insurance. What would be the best way to wire into a 6th gen with fuel pump control module. Anyone with experience? Thanks
Hughes is offline   Reply With Quote
Old 03-13-2018, 06:56 AM   #2
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
I'm running the VMS Voltage booster
https://jannettyracing.com/products/...oltage-booster
Was very simple to install and setup. This particular one comes with a very long harness that you run along the door sill under the carpet and it has a plug and play harness that you connect your gas pedal into. Similar to the Vitesse Throttle controller.
The main unit is in the back and splices into the FPCM main 12volt power supply. The rest is simply configuring how much voltage you want to send the unit and where on the throttle pedal to activate.
Dysan911 is offline   Reply With Quote
