Old 03-09-2018, 10:56 PM   #1
EXT03
Drives: 2018 CAMARO 2SS
Non rs to rs headlights issue
Hey guys I have a 2018 3.6 I installed them and when i did battery was unplugged. When I turned on the car it came the the check engine on and not reading the tire pressure and the npp for the exhaust not working it stayed open it doesn't close ......AM leaving it unplugged for more then 30 min am see if it fixes it self ....if it doesn't what have u guys done to fix it ......thanks
EXT03 is offline   Reply With Quote
Old 03-10-2018, 09:04 AM   #2
IanCC
IanCC's Avatar
Drives: Summit White V6 M6 NPP
Did you get the RS headlight kit (for non RS models) from Gen5DIY that comes with the added wiring harness that adjusts for the non-RS wiring? If not, and as far as I know, you can’t just plug an RS headlight into the non-RS sockets.
IanCC is offline   Reply With Quote
Old 03-10-2018, 12:11 PM   #3
jlcustomz
jlcustomz's Avatar
Drives: 83 el camaro
Definitely check with gen 5diy on that.
jlcustomz is offline   Reply With Quote
