Coopers Camaro
Drives: 18 Flex Fuel LTG Join Date: Nov 2016
Guys with HD cooling
Are your front fender liners the cloth material? Or are they a formed plastic? Im trying to decide what direction to go with the GM sema style grill block off plates.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2.0T RS Join Date: Jul 2016
Felt liner with a plastic insert for the side rad venting.
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed |
Pic:
![]() Drives: 1LT RS 2.0T 8A HD Join Date: Feb 2016
If you have the HD package, DO NOT USE THE PLATES. You will starve the heat exchangers of air if you're going to USE the HD package as intended.
If you don't have the HD, you may as well install them because the plates are designed to increase fuel economy. |
Coopers Camaro
Perfect! Thank you gentleman!
Any time!
#7 |
Coopers Camaro
![]() I didn't have access to my catalog, and I was knew there must be some difference in the liners. The force from the air would have destroyed the non HD wheel liners!! I've almost got this thing installed. Working on body line fitment still.......
