Old 03-08-2018, 08:09 AM   #1
Fraxum
Fraxum's Avatar
FI and Oil Seals
I am on the fence about going FI or ZL1. Thinking at least at first of a low PSI centrifugal on my M6 SS.
I see several threads about blown seals. At what PSI is this a problem with the LT1 being revved to 6,500 often with the M6?
Also what should I do on my build to minimize or prevent a problem? Seals are a PIA.
Old 03-08-2018, 08:16 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
It should not be a problem long as you put a catch can on from the get go.
Old 03-08-2018, 08:40 AM   #3
JFM-jr
JFM-jr's Avatar
Yes proper crankcase venting. Also in alot of these blown seal situations the people come to find out theres a deeper cause like piston failure. Theres a thread over on the Corvette forum about this. The 600 wheel mark seems to be the cutoff point for piston survival. The failures above the 600 mark are said to be non detonation related and more due to the tight ring gaps.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 03-08-2018, 09:06 AM   #4
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
What he said is what was my end result. Front seal, rear seal, then found 2 ringland failures. I was also just over the 600 mark and at the top of the RPM in a 4th during a long pull when she went.
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
Old 03-08-2018, 11:48 AM   #5
steelheadrob
Tactical Garage
steelheadrob's Avatar
I will be installing a Whipple in the next couple weeks when it arrives. I am planning on installing a mighty mouse vented catch can at the same time to help minimize the risk of blowing a seal. Are there any guys that have had a blown seal while using a vented catch can?
steelheadrob is offline   Reply With Quote
Old 03-08-2018, 12:18 PM   #6
JANNETTYRACING
JANNETTYRACING's Avatar
When we do FI on a Gen 6 we install an LS3 crank seal up front, Or a Metco Crank case breather.
GM changed the design for the Gen6 Likely to reduce drag, and it's very weak like tissue paper, Sneeze and it blows out.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 03-08-2018, 12:31 PM   #7
misterjaayy
Drives: 2019 CTS-V
Quick question. Does the ringland failure cause the crankcase to blow or does the blown crankcase cause the rings/pistons to fail?
misterjaayy is offline   Reply With Quote
Old 03-08-2018, 12:41 PM   #8
JANNETTYRACING
The slightest crank case pressure can blow the seals out even without any piston ring land failure.
To answer your question Yes Piston failure causes seals to blow and not the other way around.
Ted.
Old 03-08-2018, 01:08 PM   #9
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
kind of on the subject/off the subject. I am looking for a catch can that I do not have to really do anything or think on how the routing of the hoses goes. That said, I did come from Mishimoto prior to boosted. is there anyone, anyone out there that has instructions that can accommodate to an already boosted motor?
- Maggie has you adjust the dirty side where the valley below the intake is prior to installation. due to the new routing. I'm confused as to what goes where. If someone sells this or can tell me the easiest most reliable way I'd buy from you TODAY!
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 03-08-2018, 03:35 PM   #10
brettman
Drives: 2016 Camaro SS
Here is the complete thread if you didn't see it
http://www.camaro6.com/forums/showth...degree+fitting
brettman is offline   Reply With Quote
Old 03-08-2018, 05:28 PM   #11
SSDanny
Drives: 2017 Camaro SS M6
So if going FI, and only planning on staying around the 600whp figures, the best way to prevent engine failure would be a catch can and new pistons/rings? As well as fuel mods for SS models? Anything else I'm missing?
2017 Camaro SS - Kooks Long Tube Headers 1-7/8th - EFI Flex Fuel Kit - Megan Racing Coilovers - FORGESTAR F14's 20x9.5 & 20x11
SSDanny is offline   Reply With Quote
Old 03-08-2018, 05:41 PM   #12
KingLT1
KingLT1's Avatar
No you don't need piston rings at that power...most of the failures are guys running over 600whp on the stock fuel system and start going lean on long pulls. Yes the ring gaps are tight on LT1's and some are tighter then others...kind of like women.
keep it around 580whp with a catch can/breather setup(mighty mouse) and you should be fine with nothing else.
Old 03-08-2018, 08:25 PM   #13
Brianw36
SNSTRSS
Brianw36's Avatar
Drives: 2016 Camaro 2SS A8
Metco
Ted.
What part number metco do you use?
2016 Black Camaro 2SS A8 NP
Brianw36 is offline   Reply With Quote
Old 03-09-2018, 07:01 AM   #14
JANNETTYRACING
With proper fuel supply and tuning the engine can live a long happy life at 600 RWHP.
The stock fuel system is capped out around 580 RWHP, those who push the limits of the fuel system are learning the hard way.
Ted.
