![]() Drives: 2018 1SS M6 Summit White, MRC & NPP Join Date: May 2016
Over Rev
Hello - today while driving about 82-89mph, I meant to go from 6th gear to 4th, but accidentally grabbed 2nd. When I started letting the clutch out, the car decelerated quite a bit. I *think* I depressed the clutch before letting it all the way out, but I don’t remember. I do know that the RPM gauge was at or over redline. The car ran perfectly normal afterwards. I parked it at home for about an hour, and took it for another spin. Nothing out of the ordinary. Am I in the clear or can I expect stuff to start going wrong?
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 SS M6, NPP Join Date: Apr 2016
Damn you did a money shift. Hopefully everything is okay cuz if something were to go wrong the dealer can see that it over revved and use it against you.
No codes, no limp mode, etc.. you should be fine tho |
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Mar 2016
Mechanical over rev In most cases you would bend a pushrod but the car would certainly not run smoothly if so.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
lol, you are fine. if an over-rev did damage, you would know right away... trust me.
Heres a tip so it never happens to you again: Drive with REV MATCH ON haha. Its saved my ass a couple of times, as the car will auto rev to the point of fuel cutoff before you even release the clutch, keeping you from mechanically over-revving the engine. Seriously dont sweat it. These engines are engineered with this sort of thing in mind, as these are passenger vehicle engines, and not super tuned race engines.
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
A mechanical over-rev will happen with or without fuel as well as with or without a spark. |
![]() Drives: 2013 Camaro ZL1 Join Date: May 2017
Avoid skipping gears when downshifting, rather go 6-5-4, you will be far less likely to make this mistake, skipping gears is not only risky, its more work for the synchros and can wear them faster (though I doubt it will have much of an effect).
That being said you will be fine. The Camaro SS does 80 mph at 6500 rpm in 2nd gear, if you were slightly over 80 mph you would have been around 6700 rpm, which is only slightly over red line (6600rpm fuel cut off) and won't be a problem for that very short period of time. |
#7 | |
The OPs mistake was skipping gears, he should have gone 6-5-4, 6-4 is not only risky, its more work for the synchros and can wear them faster. |
#8 | |
SoCal HT5! SD
You can not over rev the engine with the clutch pedal depressed. Rev match will let you know you ****ed up before you even release the clutch.
#9 |
376 cubic inches of fun
Nannies do not prevent mechanical over-rev.
Automatic transmission is under-appreciated. |
#10 |
![]() Drives: 1987 Z28, 385cid, '16 Camaro 1SS Join Date: Feb 2016
You should be fine, you did mechanically over rev the engine, but luckily not by too much. I wouldn’t think you hit 7k rpm. I know I’ve hit the fuel cut off in 2nd at least 4-5 times. It’s not the same thing but it’s still 6500-6600rpm.
02/23/16: 1100, 03/16/16: 2500 # TGHR6N
03/16/16: 2500, 03/18/16: 3000 TPW : 4/11/16 04/8/16: built & VIN 04/11/16 - 04/28/26 : 4B00 Bayed QC hold, 04/29/16 : 4200 Rail yard '16 1SS 6M, black with jet black interior, split spoke gray machined faced wheels, and black front/rear bowtie emblems. |
#11 |
![]() ![]() ![]() Drives: 2021 Tesla Model 3 LR Join Date: May 2016
His point is with active rev match, it would send the engine to redline and hopefully the driver would go, " WTH why is the engine hitting the limiter" and then realize they shifted into the wrong gear before letting out the clutch. Of course if one doesn't catch it and lets out the clutch, then you're doomed to the mechanical overrev.
#12 | |
![]() Drives: 2016 Camaro 2SS Join Date: Nov 2016
What he's saying is the rev match happens instantly giving you a little extra warning that you F'd up. And he's right. Sent from my iPhone using Tapatalk |
#13 | |
Resident Disciple
Drives: 2010 CTS-V 6MN '98 Camaro SS (Sold) Join Date: Dec 2007
Therefore, when the clutch is "disengaged", your foot is holding down the clutch pedal. Think of the clutch as something that connects the engine to the transmission, and when this mechanism is "engaged", permits the engine and transmission to work together to move the car. When the clutch is "disengaged", the engine basically is separated from the transmission (by pressing the clutch pedal down). The bottom line is that the engine most certainly can be over-revved mechanically when the clutch is "engaged". The common mistake here, is thinking that one "engages" the clutch when you press down on it - when it is exactly the opposite that is true. With all that being said, the chances are that no damage was done to the engine - especially if it seems to be running normally. The only caveat here that I can think of would be a scenario where the over-revving incident could have possibly weakened the valve springs to the extent that if the same incident were to be repeated, a bent pushrod might be the consequence, due to the weakened condition of the valve springs (ask me how I know), but that's doubtful based on the description of the incident which was not extreme at all. Best regards, Elie
2010 Cadillac CTS-V 6MN Thunder Gray
1998 Camaro SS # C079 SOLD |
#14 | |
SoCal HT5! SD
